Old server PSUs - Uses
  • tmcw
    • Oct 2010
    • 382
    • Ireland
    I got an old (2001) server PSU the other day, a Dell branded NPS-330CB-B. Looks to be well-built, Rubycon and Nichicon caps inside (no signs of bulging), nice big heatsinks, just feels like a well built unit. Has "Newton Power Ltd" printed on one of the boards inside.
    In addition to a load of molex connectors, it also has a 16-pin and 24-pin what I presume are motherboard connectors, but it doesn't have the usual green wire I would expect for power on. Is there a way to force the power to switch on to see if the output voltages are ok? Also, are the connectors likely to be propriety, and maybe not work (or damage) a regular motherboard without modification?
    Finally, I don't run servers, and unlikely to; am I likely to find a good use for the PSU if it does work fully, or will it only be good for parts perhaps? Doing a bit of googling I can see some radio control groups seem to use these as battery chargers, but are there any other uses for them?
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: Old server PSUs - Uses
    That is made by Newton Power, which is a division of Delta Products. You may be able to get some info on it if you try their tech support by e-mail.
    PeteS in CA
      master hoarder
      • May 2008
      • 12175
      I don't have experience with this PSU, so I can't say for sure. Best way would be to open it and trace the wires to the PSU board to see which rail is on which wire, then compare the wires on the motherboard connector of this PSU and a standard ATX PSU.
      If all of the required/standard ATX voltages are there, then you could probably just rewire it and use it as a standard ATX PSU.
      Pictures may help.
      • c_hegge
        • Sep 2009
        • 5219
        I did that to an NMB 460W PSU I have. It is an excellent PSU, with entirely NCC caps, and it weighs a ton, but the ATX connector pinout wasn't standard. After a bit of re-arranging the pins (and splicing a couple of wires), it's an excellent standard PSU (albeit a bit loud)
          HP ZBook 15v G5 Mobile server 15v Specification for Upgrade or Repair
          This specification for the HP ZBook 15v G5 Mobile server can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15v G5 boardview and 15v G5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ZBook 15v...
          09-06-2024, 11:39 AM
        • japlytic
          What do you repurpose server PSUs for?
          by japlytic
          So far, I have repurposed server PSUs (all hot swap) for the following:
          • Portable multi-purpose test set with dual channel variable PSU
          • Variable frequency/voltage electrically isolated pure sinewave AC inverter
          • Low noise quad channel 0-600V DC PSU using UPS transformers with an inverter based on a trailing edge dimmer
          If you have repurposed at least one server PSU, please let me know what your application is.
          11-02-2020, 11:23 PM
        • japlytic
          Why hot swap server PSUs are derated for lower line voltages
          by japlytic
          I compared two 1200W units (both with active PFC) around the same manufacturing time, an ATX unit and a compact hot swap server unit: the ATX unit had 780uF input DC filtering capacitance compared to 390uF for the server unit, and the server unit had smaller PFC components (and heatsinks) for its size.
          Also, the ATX unit was rated at 1200W output under full line voltage range, but the server unit (full rating at 200-240V line input) was derated to 900W at 110-120V input and 800W at 100-110V input.
          Typically (in my belief) in a 100-120V region, server rooms have 220-240V mains...
          02-18-2019, 12:53 AM
        • harp
          Comparing FreeNAS, FTP server, SMB server, multimedia server...
          by harp
          I thinking about some central LAN file server, on where I can put some files from other devices, or access to them, and maybe play some movie without download...
          I never study this, but when I see that freenas need few gigabyte of ram to recommended working, some wiered partition, I wonder if I miss somewhat in the midletime...
          Also exist "turnkey file server", and other turnkey products that I can not distinguished what is major difference and how it perform - no experiance at all.
          What is general difference between this products, and what be most useful...
          01-04-2024, 02:44 PM
        • omega
          Troubleshooting of redundant F750E-S0 Dell PowerEdge Server
          by omega
          Hello all,
          as a beginner electronics hobbyist, after a few years I would like to place another post on this Forum section, given that I did not succeed in finding any useful advice among the other posts.
          Over the last years, I have been using a PowerEdge Dell Server with two redundant PSUs, namely the 750W F750E-S0 ones (aka 06W2PW). Unfortunately, last summer one of them failed (perhaps owing to an overheating), and the server had for working to take into account the other one only. Of course I opened and tried to troubleshoot the failed PSU, but each cap I tested seemed to...
          02-09-2024, 03:34 PM
