Why hot swap server PSUs are derated for lower line voltages
  • japlytic
    • Oct 2005
    • 2086
    I compared two 1200W units (both with active PFC) around the same manufacturing time, an ATX unit and a compact hot swap server unit: the ATX unit had 780uF input DC filtering capacitance compared to 390uF for the server unit, and the server unit had smaller PFC components (and heatsinks) for its size.
    Also, the ATX unit was rated at 1200W output under full line voltage range, but the server unit (full rating at 200-240V line input) was derated to 900W at 110-120V input and 800W at 100-110V input.
    Typically (in my belief) in a 100-120V region, server rooms have 220-240V mains power, and I have seen server PSUs which require a three phase AC input, one of which was an IBM unit built by Fuji Electric.
  • Curious.George
    • Nov 2011
    • 2305
    • Unknown
    Re: Why hot swap server PSUs are derated for lower line voltages
    Most servers are 110VAC machines. Typically with dual redundant power supplies (but you could still use a single 120V branch circuit to power them; a pair of branch circuits if you want to protect against a branch circuit fault). You're pressed for space when you're trying to cram that stuff into a 2U form factor which means power supplies have to be smaller/sleeker.
    Larger blade servers move up to 220V mains -- but that's usually because the power required starts to creep upward beyond what you can comfortably find on a 20A branch circuit; mine (14 blades in 7U) has a pair of 2300W power supplies in it (I have to plug it in where my electric clothes dryer resides when I want to use it).
    Disk farms tend to be bigger pigs. But, not because any single shelf needs gobs of power; rather, because its common to put a dozen or more shelfs in a single rack! (figure ~700W/shelf)
      by momaka
      03-12-2025, 03:42 PM
    • ngml
      Repair of an LG split AC system indoor unit PCB
      by ngml
      I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
      This indicates an error in the communication between the outdoor and the indoor unit.
      The outdoor unit is fine, so the problem is the indoor PCB.
      The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
      I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
      Does anybody have the schematics of this board,...
      02-01-2025, 12:55 PM
      HP ZBook 15v G5 Mobile server 15v Specification for Upgrade or Repair
      This specification for the HP ZBook 15v G5 Mobile server can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15v G5 boardview and 15v G5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ZBook 15v...
      09-06-2024, 11:39 AM
    • CoinCoin88
      Garage door RX unit (Cardin S38C) does not short relay to send opening signal
      by CoinCoin88
      I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
      Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
      09-15-2025, 03:36 AM
    • DrDos
      Unit runs but no speaker output kenwood KR-6030
      by DrDos
      I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
      09-14-2025, 09:57 PM
