So today I looked in my box of junk and came across a TopSwitch 200.
Its a easy to use controller for SMPS, and I made a small psu on breadboard already. Seems to go into shutdown with a slight load, so I think I have to try a different transformer. Here is the circuit that I used (TOP200 is slightly less powerful than TOP202, but in same package and pinout). Pics to come tm!
. Reason for that was because I accidentally misplaced the jumper for their ground and instead had it wired to 12V. The (+) side of these caps was connected to the 2.5V output of a buck-regulated power supply that I was building and testing. So basically those caps were in reverse at almost 10V. The Panasonic actually held in there pretty long - took me several minutes of testing the circuit before I noticed it was bulging. After noticing, I though maybe it was inadequate so I substituted it with the Rubycon and changed the minimum load resistor on the 2.5V output to 10 Ohm (since the circuit was unstable and I thought this would help). It took only about 10 seconds of runtime before I noticed the Rubycon was very hot and bulging as well. Only then I started checking my circuit and found my mistake
