TOP200 15W PSU project
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    So today I looked in my box of junk and came across a TopSwitch 200.
    Its a easy to use controller for SMPS, and I made a small psu on breadboard already. Seems to go into shutdown with a slight load, so I think I have to try a different transformer. Here is the circuit that I used (TOP200 is slightly less powerful than TOP202, but in same package and pinout). Pics to come tm!
    Muh-soggy-knee
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: TOP200 15W PSU project
    Darn!
    Well I accidentally pushed the snubber off the breadboard while taking measurements, and of course within seconds smoke came out of the TOP200 ....
    Muh-soggy-knee
      master hoarder
      • May 2008
      • 12175
      Oops .
      High voltage and high current always guarantees cool fireworks, especially on a breadboard.
      Try putting a 10, 20, or 30W light bulb in series with the PSU next time. That way, if something goes wrong, light bulb will become lit and you may be able to save your components (of course, if your light bulb is too powerful, components in the PSU will eventually overheat and burn - still, you would have some time to react when you see the light bulb becoming lit).
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Originally posted by momaka
        Oops .
        Yeah I might use a lightbulb next time. I have been using two 14v 28w transformers back to back for isolation
        The TOP200 squirted out a bit of black goo when it fried xD
        Muh-soggy-knee
          master hoarder
          • May 2008
          • 12175
          Ah ok, at least you're using some kind of current-limiting protection. I thought you were just plugging things straight into the mains.
          Well, I myself had 2 incidents as well last week, in both of which I ended up killing caps - and not just any caps but good caps (a 16V 1500uF Rubycon MCZ and a 16V 330uF Panasonic general purpose cap). Both overheated and bulged . Reason for that was because I accidentally misplaced the jumper for their ground and instead had it wired to 12V. The (+) side of these caps was connected to the 2.5V output of a buck-regulated power supply that I was building and testing. So basically those caps were in reverse at almost 10V. The Panasonic actually held in there pretty long - took me several minutes of testing the circuit before I noticed it was bulging. After noticing, I though maybe it was inadequate so I substituted it with the Rubycon and changed the minimum load resistor on the 2.5V output to 10 Ohm (since the circuit was unstable and I thought this would help). It took only about 10 seconds of runtime before I noticed the Rubycon was very hot and bulging as well. Only then I started checking my circuit and found my mistake
          I cut the vent on the Rubycon today to see if the pressure was gone - it wasn't! Thankfully I was wearing safety goggles and was pointing the cap away from my face when I did this - it did spray a lot of electrolyte out. The Panasonic is still bulged and hard as a rock, so it probably still retains its electrolyte. Might vent it as well.
          Definitely need to give these troopers proper burial ceremony . Maybe even a 21-gun salute.
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Haha lol, exploding caps aren't funny!
            I almost had a 2200uF 35v cap go off in my face before, I realized it had bulged and I could hear it bubbling. Accidentally reversed polarity xD
            And lol noo, I would never plug projects straight into mains!
            Muh-soggy-knee
            • repair-it
              TOSHIBA DLP 52HM95 How to reset timer module on bulb
              by repair-it
              I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
              Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
              10-11-2023, 07:18 PM
            • ezenia
              LUMIMAN Smart Bulb IC ID?
              by ezenia
              I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
              In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
              04-28-2025, 05:56 PM
            • BOSCHNJAK
              by BOSCHNJAK
              ABOUT ME INTRODUCTION FILE
              2
              024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
              2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
              2022 BEV, PROJECT ?
              2021 BEV, PROJECT ?
              2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
              2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
              12-28-2023, 02:09 PM
            • Smartec82
              The Project ID of the Thomson 55UC6406
              by Smartec82
              Does anyone know the Project ID of the Thomson 55UC6406 , panel: LSC550FN11-906? The picture appears duplicated and I can't change it in the service menu. I can only change the Project ID by pressing 062598, pressing 3 dashes, ID.
              10-03-2025, 11:30 AM
            • JimBanville
              Replacing incandescent bulb on Pioneer LD player with led. Need help :)
              by JimBanville
              I have a pioneer dvl-909 LD/dvd player from 1998. It has a light on the front panel that lights up when you play a dvd. I removed the bulb and it appears to be a tiny incandescent bulb. Its measures "open"/dead and the bulb is black like it's blown. The socket it fits into measures 5v. I've looked up the schematics and there's no indication of the amperage. I don't want to spend any money on new parts, but I have a pack of like 100, 3v, 20ma LEDs and I have various resistors.
              Is there a way for me to determine the amperage going to the old dead bulb with my multimeter?
              01-24-2023, 07:49 AM
