Enermax Galaxy DXX 850 EWL
  • Gibbo
    • 5
    Hi All, New member here; long time lurker, first time poster!
    I've searched everything I could find related to Enermax here and am looking for a little guidance.
    I run a Dual Quad Xeon with the Enermax EGX850EWL PSU. I couple of days ago it just died and the PSU power switch was still lit but no LED or indicator buzzer. I googled around and read anything I could find, then opted for the "let's open it up and see what we see" approach. (Disclaimer: The last time I seriously worked with components, Valves were still in fashion!)
    Apart from a rabbit warren of dust bunnies I quickly found that the 20A fuse was blown. On visual inspection all of the caps look fine and there's none of that tan glue I've read about, at least, none that I can see.
    I couldn't find a 20A fuse handy but did try a 10A which simply popped in an instant. I'll hit the store tomorrow and get the correct replacement fuse but in the meantime I'm wondering if there is a known fuse blowing issue with this PSU? It's run pretty well faultlessly for years.
    (I did try the 10A with no load just to see if the indicator LED would light so that may have been a mistake on my part, I'll rig up a light bulb load tomorrow too.)
    Any help or advice is very appreciated.
    Cheers, Gibbo
  • selldoor
    Slow Learner
    • 7870
    Re: Enermax Galaxy DXX 850 EWL
    I personally would use a hard drive as load.
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      Well, since the fuse is popped something must be shorted, so its time to get the Multi-meter out to test some of the components in the primary (HV) side of the PSU
      Muh-soggy-knee
      • Gabriel
        • Jan 2010
        • 620
        • Norway
        Might not work as most of these Galaxy's has a minimum load requirement of 50W and could turn off the power supply. Got a 850EWL myself and this has minimum load requirement.
        • Gibbo
          • 5
          Thanks for the answers so far. Yep, I understand that the 850EWL needs a minimum load and I'll be doing the component check today. What an adventure!
          • Gibbo
            • 5
            So... I pulled it apart and looked for anything obvious.
            I have a bunch of frosty looking white staining which may be leakage but still don't know if that's it.
            I've looked around for guidance but got kinda lost, can someone advise my where to start checking?
            The 20A fuse blows on 2 attempts. Ideas?
            Thanks.
            • rogfanther
              • Jul 2006
              • 458
              • Brazil
              Please, post photos of the board.
              • larrymoencurly
                • Oct 2004
                • 960
                Discharge the high voltage capacitors and then check the high voltage rectifiers and transistors for shorts?
                • Gibbo
                  • 5
                  Thanks. As much as I hate to appear to be the complete naif here, I know how to test a Bridge Rectifier when it's sitting on my bench but does the test still hold true if the rectifier is in situ ie. still in the circuit board?
                  This unit is one tightly packed board and I'm trying to fix it without completely disassembling. Is that a forlorn hope?
                  OK, I guess I should probably admit it, I'm a complete naif!
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    You should remove the bridge from the board to test it, and while your at it, remove the mosfets and test them too. Make sure to test the PFC diode and PFC mosfet too.
                    Muh-soggy-knee
                    • Gibbo
                      • 5
                      Thanks.
                        Samsung Galaxy Book2 Pro 360 GALAXY BOOK2 PRO 360 15.6 Hybrid (2-in-1) Specification for Upgrade or Repair
                        This specification for the Samsung Galaxy Book2 Pro 360 GALAXY BOOK2 PRO 360 15.6 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GALAXY BOOK2 PRO 360 15.6 boardview and GALAXY BOOK2 PRO 360 15.6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                        09-07-2024, 06:11 AM
                        Samsung Galaxy Book2 Pro Galaxy Book2 Pro Notebook Specification for Upgrade or Repair
                        This specification for the Samsung Galaxy Book2 Pro Galaxy Book2 Pro Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book2 Pro boardview and Galaxy Book2 Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                        09-07-2024, 05:50 AM
                        Samsung Galaxy Book2 Business Galaxy Book2 Business Notebook Specification for Upgrade or Repair
                        This specification for the Samsung Galaxy Book2 Business Galaxy Book2 Business Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book2 Business boardview and Galaxy Book2 Business schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
