Switching power supplies without APFC generating least AC harmonics
  • japlytic
    • Oct 2005
    • 2086
    In an Xbox 360 external power supply, it does not have active power factor correction (APFC), but uses a half-bridge topology (I incorrectly said elsewhere that it had a push-pull topology )
    Which switching power supply topology (without APFC) would generate the least harmonics on the AC line?
    The switching topologies I can think of are the forward converter, the push-pull converter (B+ is at centre tap), the half-bridge with a single input rail (i.e. 340V DC), a variant of the half-bridge, which has a centre-tap from two 200/250V electrolytics to generate positive and negative HV rails like in old-school style computer power supplies, and the full bridge.
    Re: Switching power supplies without APFC generating least AC harmonics
    The Xbox 360 PSU -does- use APFC because it consumes about 180W and is sold in the UK and Europe where APFC is almost certainly required.
    In your pic:-
    https://www.badcaps.net/forum/attach...7&d=1336720274
    You can see a yellow-coloured like transformer which is unaccounted for - this is the APFC inductor. Also 180uF is too small if it wasn't using APFC.
    I'm guessing one FET is for the APFC, the other is for a single-switch forward topology of some kind (good for output power <250W and quite efficient.) There is a through hole diode somewhere too I expect.
    As for least harmonics - one of the newer resonant tank converters which switch sine waves into the transformer (but really efficiently using MOSFETs as on-off devices.) It is quite common to see that kind of topology in LCD TVs.
    • PeteS in CA
      • Aug 2005
      • 3586
      • USA, Unsure of Planet
      If I understand your question correctly - speaking generally, not to the Xbox specifically - the harmonics reduced by PFC are a product of the capacitor filtered rectifier circuit. I don't think the inverter topology (full bridge, half bridge, forward converter, flyback) matters much, if at all.
      PeteS in CA
        07-01-2024, 06:34 AM
        03-31-2024, 02:12 PM
        Meanwell Switching power supplies intermittent every capacitor under 100uf
        Here is the eBay website link where I bought them from
        https://www.ebay.com/itm/276135936202
        I have been waiting for these switching power supplies to come well they came in today so I took one apart and found that it Capcon and EIite and another brand that is on my list of capacitors to replace on site it has several 0.47uf @ 50 volts ESR value twice the reading of a new one 10 UF @ 50 volts almost twice the ESR value of a new one 47 UF @ 59 volts with double the ESR value 100 UF almost the same as a new one it got replaced for good measure Iit was a brand if I see them...
        11-25-2023, 06:05 PM
        After all of...
        07-13-2024, 08:14 PM
      • Per Hansson
        WARNING: Live heatsinks & single pole on/off switches in switching power supplies
        by Per Hansson
        This is a warning to inexperienced and experienced techs alike:
        The De-facto standard is to have the primary side heatsink live in switching power supplies.
        That is the primary side heatsink is referenced to the negative of the bulk filtering capacitor.
        Therefore never ever touch the heatsink if the device is plugged in.
        And even if it is unplugged let the capacitor discharge first!
        Another really serious concern is that the power switch also by De-facto standard is single pole.
        This means it only cuts power to the phase or neutral (not both) depending...
        06-09-2021, 12:01 PM
