Re: UC3842 basics
Here's a preliminary schematic of what i'm playing with right now. Does 3A "in spec". Some tweaks left to do on the compensation and the snubber across the diode, but other than that it's pretty solid. More on that further down.
I won't post the PCB i made for this schematic because there are a number of things that need to be fixed in it... Trust me, it's sitting on my bench, and it's been trouble. But it is a working PCB with good layout for the most part, not a messy protoboard.
Also, as you can see, there's no input filtering yet.
Notes:
Needs a minimum load for the aux voltage to rise high enough for the 3842 to operate properly. This can be lowered by reducing R4, but expect higher dissipation in it and the zener if that's the case. Btw, like it is now, the zener is OPTIONAL... The 3842 has a built-in zener. It's not a good idea to abuse of it, but so far, it works.
It is not necessary for the secondary ground to be connected to mains earth. I made it that way in the schematic to make a clear difference between primary and secondary grounds.
The current configuration on my PCB is as follows:
There are no heatsinks on any of the parts.
Test results:
At 3A load, everything runs in the low 70s at most, with one exception. The UF1002F rectifier reached 112C with 3.5A load... at which point i went back to 2.5A where it doesn't exceed 100C. Will need to use a Schottky, and/or a small heatsink.
Output ripple is very low at all loads beyond the minimum, switching noise is low as well. It was well worth spending a few hours measuring and calculating the proper values for the RCD clamp on the primary switch.
Looks like a 5vsb transformer from a cheapo ATX PSU can actually do 3A continuous output. Most cheapies fall way short of this number however, due to poor design of the switching circuit.
That's it for now, stay tuned for more.
Also, as you can see, there's no input filtering yet.Notes:
- 1 ohm resistor for the fuse... i learnt from the Chinese.
Temporary, don't be foolish. Will install a proper fuse once i fix the PCB... not enough room. - 2A bridge rectifier
- Samxon 47uF 400v primary cap. I have a 10uF around somewhere, will try with that as well. Don't have any 22uF tho.
- 2SK2545 primary switcher (600V 6A 0.9 ohm TO-220F).
- UF1002F rectifier diode on the secondary. (200V 10A TO-220F).
- UCC KZE 1500u 6.3v after the diode.
- 4.7uH inductor for the pi filter.
- UCC KZG 820u 6.3v after the pi filter. I thought it can at least do that.
Test results:
