Buying a power supply for my Dad's PC
    My dad's old HP small form factor office PC is no longer capable of doing the tasks he demands, being an old 1.7GHz Pentium 4 processor with SDRAM-133. So, I have a spare motherboard and case around, but no power supply.
    I need to get a power supply of around 200 - 250W output power, at most, as the motherboard only has an older AMD processor on it (but still faster than his P4.) I doubt the system will draw any more than 100W under reasonable load.
    I absolutely do not trust these so called "750W" power supplies:
    http://www.ebay.co.uk/itm/NEW-QUIET-...item20c216f8fa
    As I can see no way anyone could make a 750W PSU for £20 and not lose money. They are almost certainly cheap barely capable 200W PSUs. They are also almost certainly not CE compliant and would radiate a lot of EMI. And they almost certainly have cheap caps, so they'll die after a year or so. I want this PC to last. Incidentally, the motherboard has OST caps for the CPU, so I'll be recapping it with some Nichcon HM's.
    So, I'm thinking instead of spec'ing in a used power supply, probably an old workstation one, like this: http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=400292695320
    I'm just wondering if it's a normal ATX connector - or if it's some proprietary IBM one? I know Dell had proprietary PSU connectors which meant they were pretty much tied to Dell motherboards - did IBM do the same thing? What other sources are there for decent quality PSUs which won't break the bank (budget max £25)?
  • mariushm
    • May 2011
    • 3799
    Re: Buying a power supply for my Dad's PC
    Get one of these at around 30 pounds and don't bother with eBay...
    http://www.ebuyer.com/267860-huntkey...ed-jumper-300g
    http://www.ebuyer.com/278493-antec-v...761345-06431-6
    http://www.ebuyer.com/271798-corsair...mpsu-430cxv2uk
    http://www.aria.co.uk/Products/Compo...roductId=42487
    The first you may not know the name, but the psu was reviewed and it did good .. I would dare to say better than that Corsair CX (but i'm saying from memory, check review if you want): http://www.anandtech.com/show/4069/h...0w-80plus-gold
