Dell server powersupply n730 ab a
  • klkmalik
    seeking Tips
    • Nov 2011
    • 68
    • UAE
    Hi i got dell server powerwsupply nps 730 ab a , not working .but I didt found any badcaps short components , I need power supply pinout and diagram.
    anyone have exp. soultion please post here. thanks advance.
  • dmill89
    • Dec 2011
    • 2534
    Re: Dell server powersupply n730 ab a
    Are you using this PSU in a Dell server or are you attempting to use it on another (non-Dell) system? Dell server PSUs use a 3.3VSB rather than the standard 5VSB effectively making them proprietary. If you are using this PSU with a non-Dell (or even a Dell that isn't a server) it isn't producing enough voltage on the standby rail to be able to start on a standard motherboard.
    • klkmalik
      seeking Tips
      • Nov 2011
      • 68
      • UAE
      THANKS for post, I want to repair original server power supply. i measuring voltage main caps about 320 volt dc, ofter no switching . there is fet it was ok. also no indication there three LED not working. I want to know without load it will work or not work?
      • dmill89
        • Dec 2011
        • 2534
        That I honestly don't know. I'm fairly experienced with PSUs but virtually everything I have worked on was standard ATX or similar(non-standard cases and connectors but similar in basic design to ATX). I'm not all that knowledgeable about proprietary, hot-swap, rack mount PSUs like the one you have. I also haven't been able to find much on it from web searches (apart from specs and standard stuff, no in-depth technical information) Hopefully there is someone else on here will have more knowledge/experience in this area.
        • PeteS in CA
          • Aug 2005
          • 3581
          • USA, Unsure of Planet
          Not sure how much help this will be, but that P/S was made by Delta Products (Newton Power). The nearest Delta division to the UAE is Delta Products India. Maybe you could get some information (or a referral to some one who could help) from their tech support.
          PeteS in CA
          • omega
            Troubleshooting of redundant F750E-S0 Dell PowerEdge Server
            by omega
            Hello all,
            as a beginner electronics hobbyist, after a few years I would like to place another post on this Forum section, given that I did not succeed in finding any useful advice among the other posts.
            Over the last years, I have been using a PowerEdge Dell Server with two redundant PSUs, namely the 750W F750E-S0 ones (aka 06W2PW). Unfortunately, last summer one of them failed (perhaps owing to an overheating), and the server had for working to take into account the other one only. Of course I opened and tried to troubleshoot the failed PSU, but each cap I tested seemed to...
            02-09-2024, 03:34 PM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • Akhlz001
            by Akhlz001
            09-20-2025, 07:15 PM
          • master3112
            by master3112
            07-29-2025, 01:55 PM
          • hazem3636
            need Bios Bin file Dell server 220
            by hazem3636
            hi everyone
            i need dump file for dell server r220
            i have download Flash BIOS executable file but i dont know how to conver it to Bin file
            i have check on youtube there is some programs are doing this method of creating Bin file from ExE file .
            if anyone has this method please need his supporting .
            all the best
            EXE file is attched and Original Bin file from the Bios Chip is attached also
            and dell website "https://www.dell.com/support/home/en-us/drivers/driversdetails?driverid=mrxv...
            11-05-2022, 06:20 AM
