CAPZero and SENZero
  • japlytic
    • Oct 2005
    • 2086
    CAPZero and SENZero
    I happened to find these on www.powerint.com
    The CAPZero is particularly interesting, of which the discharge resistors across the X-class capacitor(s) are open circuited when AC power is applied, and when AC power is removed, the CAPZero connects the discharge resistors, discharging the X-class capacitor(s) within one second.
    It is easy to retrofit the CAPZero in any power supply design.
    The SENZero addresses the issues of standby consumption of primary side control voltage rails.
    As I said elsewhere, Power Integrations is my first choice in switching power supply controllers - as with most others, most of the hard work has been done for you, especially with design calculators, some of which are free.
  • TinkerTron
    Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
    by TinkerTron
    Hey everyone,
    I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
    Instead, here's what's been bugging me so far:
    The schematic...
    03-06-2025, 02:03 PM
  • brightest_z
    Hot Air Blew Away Resistors Near Bios
    by brightest_z
    Hi All - I'm in the midst or reprogramming the bios on my gen1 Surface Laptop Studio and I accidentally blew away 2 resistors nearby the bios. I don't have another board to measure values of the missing resistors and schematics aren't available, bbut the bios is a 6x5mm Winbond WSON8, W25R256JWPQ model. The traces are conductive to Pins 3 and 7 (IO2 & IO3 respectively) so I have reason to believe they are 10k pull up resistors since IO2&3 pins are used for Quad SPI instructions.
    Does anyone with more knowledge, and experience than I, know if this is the case?
    12-11-2024, 08:34 PM
  • jinu_j
    LED driver circuit. Burnt Resistors
    by jinu_j
    Hi Folks
    This has to do with a LED light driver rated for Output - DC36-65V 300mA. This is used to drive a 15W LED panel light.
    Now this does not work so opened up and found 2 resistors burnt to crisp. Sensing a learning moment, i looked around the circuit to figure out that it is built around the OB2538 chip. The circuit to a large extent follows the sample application circuit mentioned in the data sheet. I have traced the actual circuit and the same is also attached for reference.
    But i have some queries on this circuit
    1. The resistors that burnt to crisp...
    08-26-2020, 01:24 AM
  • repair-it
    Pioneer VSX-40 ,Trying to ID these resistors
    by repair-it
    I am trying to determine why these two resistors are the colors that they are. This is a Pioneer amp. The ones I am concerned about are the RED & GREEN colored resistors. I need to replace them and want to be sure to use the properly rated component....
    12-16-2024, 02:08 PM
  • BustinCaps
    Dell 2007WFP resistors under white silicon blog
    by BustinCaps
    My beloved 2007WFP just died on me. It has a green blinking light that just cycles through various display numbers. For a while I noticed it would blink slightly like the refresh rate was off. Nothing I have done has been successful in turning it on. So I took it apart and looked at the USB board since many people have had problems with the resistors under the silicon blob. I looked at the various other boards for the obvious signs such as blown caps, bad fuses, burn marks etc. Nothing looked obvious. I also checked most of the caps with an ESR meter and they checked out good.
    04-29-2022, 06:19 PM
