Inductor Core and Copper Losses
  • iamakda
    • Mar 2012
    • 46
    • Denmark
    Dear all,
    I have to build an inductor of 32nH for which I have chosen toroidal core from Micrometals T12-10. I calculated the number of turns as 5 turns. #26 AWG Wire with a length of about 30mm.
    DC Current of inductor is 100 A dc where as ripple current of 40 A (pk-to-pk), operating frequency is 90KHz.
    Now how I can calculate the core and copper losses associated with the inductor.
    Please help.
    Thanks.
  • kikkoman
    • Jul 2007
    • 691
    Re: Inductor Core and Copper Losses
    wait, what? #26 for 100A peak? no way!
    you've got to do it the other way around.
    first choose your wire (i'd guess #4 or thicker for that current?!), then you choose the rest.
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
    • iamakda
      • Mar 2012
      • 46
      • Denmark
      100 A is the dc current and ripple current is 40A(pk-to-pk).....
        #26 is rated 2.2A in chassis. It will incinerate at 100Arms.
        Also, I've never wound an inductor myself, but would the skin effect prove problematic as it's only ~650Hz (maximum depth) for #4? So you may need more parallel windings to get the current you need through the inductor and to reduce the losses.
        • iamakda
          • Mar 2012
          • 46
          • Denmark
          Dear Tom66,
          I am using one online software from Magnetics (http://www2.mag-inc.com/calculators/...ign-Calculator) and they suggested 5 x #12 (AWG) wire.....so what does this mean?
            AWG #12 can carry 41A so 5 strands is fine.
            Maybe you could wind 5 x 160nH inductors on the same core and put them in parallel?
            • Evil Lurker
              Warranty Voider
              • Feb 2011
              • 454
              You do realize that a single strand of #14 gauge wire will not fit thru the center of that toroid don't you?
              • PeteS in CA
                • Aug 2005
                • 3579
                • USA, Unsure of Planet
                5X AWG #12 would be a little better that AWG #8, marginal for 100A IMO. I'd use #4 or #2.
                PeteS in CA
                • PeteS in CA
                  • Aug 2005
                  • 3579
                  Thinking about this as a whole, my BS meter is pegging! Five (5) absurdities in this post:
                  1. As has been pointed out, AWG #26 will fuse with 100A flowing through it; skin effect will make even 5X #12 wire insufficient;
                  2. As has been pointed out, a T12 core is way too tiny;
                  3. 32nH is insignificant as a filter inductor;
                  4. Micrometals -10 material is an RF material, not a power material;
                  5. Micrometals doesn't make a T12 toroid in a power material.
                  B-freaking-S!!!
                  PeteS in CA
                    Would add though I did use a 240nH inductor in a 30A DC-DC design (for a future project, among a hundred others), but:
                    - it was a three phase design (30A per phase, 450W output power max)
                    - it was a boost converter
                    - it operated around 500-600kHz
                    - it used some high power Coilcraft powdered iron inductors (50A saturation current! Micro-ohm resistance!)
                    I don't know if you could even reasonably use 32nH in a DC-DC design, because you'd either cook your transistor from using a frequency that was too low (too high peak currents) or you'd have too much lost in the transistor due to the need to switch at very high frequencies.
                    • iamakda
                      • Mar 2012
                      • 46
                      • Denmark
                      B-freaking-S!!!
                      If 5x#12 is also insufficient as you mentioned, then what wire should I use for this application and with how many strands?
                      Thanks.
                      • iamakda
                        • Mar 2012
                        • 46
                        • Denmark
                        Dear Tom,
                        How come you know #12 AWG can carry 41A?
                        Thanks.
                        • iamakda
                          • Mar 2012
                          • 46
                          • Denmark
                          Hi Kikkoman,
                          how many strands of #4 wire should be used?
                          Thanks.
                            Originally posted by iamakda
                            Dear Tom,
                            Thanks.
                            http://lmgtfy.com/?q=awg+current+rating&l=1
                            • iamakda
                              • Mar 2012
                              • 46
                              • Denmark
                              Thanks a lot Tom
                              Have you ever ever designed the output filter for DC DC Boost Converter?
                              Thanks.
                                " The Maximum Amps for Chassis Wiring is also a conservative rating, but is meant for wiring in air, and not in a bundle. For short lengths of wire, such as is used in battery packs you should trade off the resistance and load with size, weight, and flexibility. NOTE: For installations that need to conform to the National Electrical Code, you must use their guidelines."
                                  Thanks a lot Tom
                                  Thanks.
                                  No formal education (yet!)... I just add lots of capacitors until it works :P.
                                  For a 100A supply with a 40A inductor ripple current it is absolutely essential you use ceramic capacitors or ultra low ESR poly capacitors. (You will need a lot of them... at 3Arms ripple each, that's at least 12 but that won't last long, so figure twice that for long life.)
