PSU problems(More inside)
  • oke139
    • Feb 2012
    • 13
    • Estonia
    Re: PSU problems(More inside)
    Alright, il try to take better pictures later & get a multimeter, but what i can tell they should be parallel. Do PSU's caps got some kind of bleed resistor that empties the caps or should i be on the lookout for leftover power in the caps? LOL i hope i dont hit the jackpot with connecting + with -, gota get my dad with this Once i was replacing an display in a digital camera and the freakin cap was hidden behind the board, i was extra cautious but then bam, i got shocked, turns out i found the soldier points for the cap on the motherboard... Was quite a shock too...
    • PeteS in CA
      • Aug 2005
      • 3586
      • USA, Unsure of Planet
      There should be bleeder resistors across the input electrolytics. Unless you already have the case taken apart, the resistors should have the caps bled off by the time you can open the case and get your hands inside. Of course, if you are already looking at the bottom of the PCB, measuring the voltage across the input electrolytics won't take long and might save you an unpleasant surprise.
      PeteS in CA
      • oke139
        • Feb 2012
        • 13
        • Estonia
        Alright, today my replacement PSU(some cheap 300w, no graphics card installed) started to malfunction too and a PSU before that was malfunctioning also. So im starting to think maybe PC's motherboard can have something to do with this, gonna try graphics card + psu on friends system laterz. Anyway i added some pics of my PSUs motherboard. My dad said they run on seperate circles but hes been known to be wrong sometimes. Also i was looking at a modecom PSU today, are they any good? It was premium i think.
        • oke139
          • Feb 2012
          • 13
          • Estonia
          I'm getting a new PSU instead. I was wondering what you guys think of Matsushita caps (Japanese made)?
          Moral of the story: It's very hard to get quality 8mm caps and its not worth the trouble if you don't live in UK or US, now 10mm that is easy
          • dmill89
            • Dec 2011
            • 2534
            Matsushita is the parent company of Panasonic and their caps are some of the best out there.
            • PeteS in CA
              • Aug 2005
              • 3586
              #26
              Matsushita = Panasonic = Goodness.
              PeteS in CA
              • oke139
                • Feb 2012
                • 13
                • Estonia
                #27
                Alright i already paied for it. This time im getting something real nice instead of a cheap one. A Gigabyte Odin GT 550W. It has all the cool monitoring & calibrating stuff like manually raising the voltage on rails(I know, i wont go even near that slider lol). It was stated that it uses those caps and with your feedback im pretty sure this will last me sometime and even if the caps fail sometime i hope they use 10mm ones .
                THANKS A LOT EVERYONE
                E: Oh and i was wondering if there were any other stuff that failed frequently on PSU's other than capacitors?
                • Flaku_34
                  Acer Nitro XV273 and Predator XB273, look inside and disassembly guide.
                  by Flaku_34
                  Introduction:
                  Hello everyone, this topic is more of a knowledge sharing and look inside type of post, but for someone working on this model of display it might be useful. Recently I bought Acer Nitro XV273 XB MIIPRZX with busted electronic, but screen was intact, price was incredibly low, so I took a gamble and bought the unit and try to fix it. As I dug inside, I found out that my motherboard was not responding, although all voltages seemed fine. I wasn't able to find any reliable information about this monitor on the web (only some pictures of motherboards from Ebay). By some research...
                  04-18-2024, 12:47 PM
                • dragon3x
                  by dragon3x
                  power on.
                  Here are some examples :
                  switching supply area).
                  than 6.3 V.)
                  03-21-2025, 02:46 PM
                • Cama
                  Solar Inverter - SMH-II - 2 missing capacitors
                  by Cama
                  I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
                  My model is : EASUN SMH-II 7 KW
                  Mother Board : P/N 18947-002401250250
                  Maybe the EASUN SMH-II 4.2 KW have the same capacitors
                  Thank you...
                  09-12-2025, 02:50 AM
                • NicRac
                  monowheel repair,Is the diode the problem?
                  by NicRac
                  Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
                  First of all, I am new here. Therefore I will shortly introduce myself.
                  I am Nico and currently I study Physics.
                  In my freetime I like to build and repair stuff. Especially big battery's.
                  A few years ago I got myself an electric unicycle, monowheel or however you call that.
                  The battery bms was broken so I replaced and resolder that. Nothing big.
                  I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
                  07-26-2024, 06:13 AM
                • Ady2017
                  Are there any datasheets available for Elna RJG capacitors?
                  by Ady2017
                  I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                  05-25-2025, 02:19 PM
