Ryobi One +Charging Center for Lithium Ion Battery chagrer
    • Jul 2011
    • 6070
    If any one has one of these chargers you may want open it up and see if it has CapXon brand caps in it one has already has pop it top
    Here is how you can tell if you have a problem if the red LED light is flashes{ it should stay ON} with out a battery in it to charge and if you put a battery to charge the green LED light flashes like it should how ever if you remove the battery the green LED light stay it should change to red
    In the next day or so I will take a photo of the charging board
    • Jul 2011
    • 6070
    Re: Ryobi One +Charging Center for Lithium Ion Battery chagrer
    UpDate
    I recaped one of my charger and it work very good now
    I open the other charger which is the same model it has the same caps and the same cap pop it's top as well 1000 uf @ 50 volts Capxon brand cap most of them
    I recap it for the most part with FC brand caps
    • delaware74b
      • Apr 2009
      • 628
      It looks like I'll be cracking open my Craftsman C3 Li-Ion charger this weekend. The Ryobi (Home Depot) and Craftsman tools are the same, despite the voltage difference (18v Ryobi vs 19.2v Craftsman).
      The LED indicators operate the same way on both brands, so I'm betting the chargers are the same.
      Stupidity should be a crime, especially for drivers. I have NO patience for them.
      • mockingbird
        • Dec 2008
        • 5488
        I re-capped a generic Chinese charger not too long ago... The problem was that it wasn't fully charging NiMH batteries and the red LED was never turning green indicating a completed charge cycle. After re-cap, everything worked great.
          • Jul 2011
          • 6070
          I also have a Craftsman C3 Li-Ion
          They are very close to the same thing how ever some of the cap values are different the same caps had pop it top
          I had a battery that it said it was bad how ever when I recap 1/2 of it the caps that I have on hand it charged that pack now I do not know how good this pack is at this point
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • Julian Bailey
            HP ProBook 445 G8 Battery not charging
            by Julian Bailey
            Hi all
            We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
            The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
            I have gone around the board with a MM and cant find anything
            Windows shows the battery fine,...
            10-11-2024, 10:34 AM
          • mferna14
            Samsung NP750XDA not charging battery
            by mferna14
            Dear gentlemen., today working on a Samsung Galaxy NP750XDA Laptop (NB3586-NB3587_PCBN_MB_V5), not charging battery. The laptop came with a dead battery & upon testing the battery Ouput coil getting around 6v, assuming that the battery circuit is ok & only the battery has to be replaced. I ordered a new battery, received & installed it but still same, NOT CHARGING. In the start, on the battery + pin I get 17v which is perfect for a 15.4V battery & then the volts drops down to 6v approx & does not charge or work on the battery & the charge LED comes on & then off. I...
            11-23-2025, 12:31 PM
          • kodox
            ThinkBook 15 G3 ACL Not Charging Battery - LA-K602P Board
            by kodox
            since i couldn't find schematic or boardview for this model (LA-K062P), i use closest board model found here https://www.badcaps.net/forum/troubl...-and-boardview
            the schematic share same marking for each component, using same PD-Controller, same BQ25710, the only different is the battery cell used. LA-K061P uses 3S battery while LA-K062P use 4S battery per schematic.
            what i've done:
            - flashing...
            12-29-2024, 02:49 AM
            12-31-2023, 06:04 AM
