Please help to identify this resistor in desktop FSP power supply
  • Ray Kaminek
    • Jan 2012
    Can anyone help to identify this blown resistor for replacement purposes.
    Desktop Power Supply FSP300-60BTV
    Blown resistor R34
    It's an old PC but I want to make it work for a little longer.
  • c_hegge
    • Sep 2009
    • 5219
    Re: Please help to identify this resistor in desktop FSP power supply
    Where abouts on the PCB is it located? I have an FSP300-60ATV, which I'm assuming is similar, but may not be totally identical.
    • gica69
      Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
      by gica69
      I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
      Resistor shows orange range silver gold and green lines.
      Thanks in adv...
      07-21-2025, 09:49 PM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • jinu_j
      by jinu_j
      Hi
      05-03-2025, 10:51 PM
      03-31-2024, 02:12 PM
      HP Slim Desktop S01-aF0005na Slim Desktop S01 J5005 Specification for Upgrade or Repair
      This specification for the HP Slim Desktop S01-aF0005na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-aF0005na boardview and Slim Desktop S01-aF0005na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
      09-12-2024, 03:28 PM
