atx YLP-013 Repair help please
  • humblesmith1
    Marine555
    • Dec 2011
    • 22
    Re: atx YLP-013 Repair help please
    Started it up and the 5Vvsb output is 5.89 volts.
    No smoke
    No other outputs
    Will have to check the WT7520 when I get more time.
    What regulates the 5vsb? seems a little high.
    • 370forlife
      Large Marge
      • Aug 2008
      • 3113
      There is a 50v, 47uf cap near the 5vsb transformer that might need to be replaced.
      • humblesmith1
        Marine555
        • Dec 2011
        • 22
        Thanks I'll pull it and check it out. I think that I have one here and will just replace it.
        Any ideas about the main supplies?
        • humblesmith1
          Marine555
          • Dec 2011
          • 22
          The cap reads 47 uF.
          Any other ideas?
          If I check ripple with scope on the bench , what should I expect?
          • humblesmith1
            Marine555
            • Dec 2011
            • 22
            The 431 reference has 2.525 volts on one side and about 1.94 on the other.
            The 5vsb output is now 5.6 vdc with 140mv ripple (still a little high)
            No other outputs up yet.
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              #26
              TL431 looks ok. Try replacing the optocoupler in the 5vsb circuit. These circuits are built ass-backwards - as the opto goes weak or if the resistors setting the divider go open, voltage goes up. WT7520 has a maximum voltage of 5.5v - if it ever went much past 6v the WT7520 could have died.
              A working TV? How boring!
              • humblesmith1
                Marine555
                • Dec 2011
                • 22
                #27
                Thanks a lot!
                I'll try to find an optocoupler.
                Is the fairchild H11AA817C the right part?
                And I'll check the divider resistors.
                Do you know what values they should be?
                Don't know where to buy a WT7520, do you know of a supplier?
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  #28
                  Anything with 817 in the part number will do for the opto, they're all compatible. Most of the time i see Everlight EL817 or Cosmo ones. As for the WT7520, unfortunately i have no clue where to get one, short of another similar PSU.
                  • humblesmith1
                    Marine555
                    • Dec 2011
                    • 22
                    #29
                    Thanks Again.
                    I'll try to get the parts and the see......
                    • humblesmith1
                      Marine555
                      • Dec 2011
                      • 22
                      #30
                      installed the opto
                      output = 3.6 v
                      found low esr 470uF 10 v needs replacing
                      • humblesmith1
                        Marine555
                        • Dec 2011
                        • 22
                        #31
                        can't find the main chip
                        now it is garbage
                        I learned a lot though
                        • rattman
                          • Dec 2015
                          • 18
                          • US
                          #32
                          I know this is an old post. I have the same power supply
                          450 Watt and was wondering if you know the value of C28?
                          Hope I'm in the right place. Thank you in advance.
                          • Bill Sullivan
                            • Feb 2022
                            211 pico 1KV
