What will happen to 3phase source or load when the 3phase load Line 1 is connected to 3phase source Line2.
3 phase connection
Re: 3 phase connection
Well if the load is the only load on the source e.g transformer the unbalanced load causes magnetic flux to escape the core causing heating of the enclosure.
A motor connected in the way you described would not run and over heat.
I guess you mean like this.
------ \_-----
--------------Last edited by joshnz; 12-04-2011, 06:52 PM.My pc
CPU : AMD PHENOM II x4 @ 3.5Ghz
MB : ASUS M4A89TD PRO USB3
RAM : Kingston ValueRAM 16gb DDR3
PSU : Cooler Master 850W Silent Pro
GPU : ATI Radeon HD 6850 -
Here is a clearer image.
Second image is wrong phasing.Attached Filesif you find these attachements useful please consider making a small donation to the site
My pc
GPU : ATI Radeon HD 6850Comment
And if you have three single-phase loads supplied from a 3ph Y source, nothing will happen.
Take a few 277V T5s for example. Row 1-A, row 2-B, row 3-C. You can mix them up all you want, just make sure you don't smoke the neutral by putting two or more MWBC feeds on the same phase. That also applies to the 20A SABC(s) for resi kitchens, although with SP GFCI/AFCI bkrs, that won't work (anymore).
http://forums.mikeholt.com/showthread.php?t=132830
Saves repeating what's already been said.
-Paul"pokemon go... to hell!"
EOL it...
Originally posted by shango066All style and no substance.Originally posted by smashstuff30guilty,guilty,guilty,guilty!
guilty of being cheap-made!
Thank's kaboom you helped me just confirm one of my theories about balancing for a long time I have wondered why the neutral/ground on the power distribution system could be small compared to the phases here the system is delta wye 230 400 / 240 415My pc
Kaboom - I've dealt with the aftermath of a 3-circuit, 277 volt (3-phase) lighting system where the neutral failed. Bear in mind, this was within a modular wiring system (read it as plug-and-play). 22 T5HO 4-lamp and 22 T5HO 2-lamp ballasts blew up, they didn't even bother to smoke
I'm guessing they didn't like the 480-volts due to no neutral.
The customer wasn't too happy with the bill for repairs with took 2 days to be fixed. They lost 1/3 of their lighting in the entire store from a single neutral failure.Stupidity should be a crime, especially for drivers. I have NO patience for them.Comment
by AJ847.63eHi Folks,
Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't... -
This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-12-2024, 02:20 PM
This specification for the HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load & Asset Tag boardview and 1050 G1 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...09-06-2024, 10:56 AM
This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...09-06-2024, 10:56 AM
- Loading...
