HP54501A 100 MHz digitising oscilloscope power cycling
    I have had this scope for about 3 years now. I bought it working.
    After about a year of use, it developed a problem where it would reset itself randomly while in use. After a while it would keep cycling, seconds between resets.
    The trace also tends to go to the maximum value when this happens too; I believe this is because the analog supplies were going out of tolerance.
    Initially, I gave it a good clean and sprayed contact cleaner on the main connectors. That fixed it for about 2 years...
    And now, it's doing the same thing... but cleaning hasn't fixed it...
    So the question is what causes a supply to act like this? Why would it work fine for 2 years after cleaning it? What did the cleaning fix?
    This is a very old supply. The scope was manufactured in 1993. The supply is capable of about 200W and is air cooled by a fan at the rear. (The fan also cools the rest of the instrument.)
    It looks like a single power NPN forward with a very large transformer. Picture attached.
    The supply is controlled entirely in discrete logic, as well as an LM339 comparator. There are no actual SMPS controller ICs anywhere on the board.
    All caps are Chemicon or Rubycon.
    This is a very nice power supply and an example of sheer overengineering. Look at the sheer number of capacitors on just one rail - 8 x 35V 1000uF (for the +15V supply, which runs the CRT and fan, and nothing much more.) On the +3.5V rail, there are 3x 6.3V 6800uF. So for now I'm going to rule out the capacitors as being the problem. No bulging or bloating anywhere on the caps.
    There are even some surge arrestors on the input (spark gaps) as well as a very beefy line input filter.
    Any help would be much appreciated...
  • retiredcaps
    • Apr 2010
    • 9271
    Re: HP54501A 100 MHz digitising oscilloscope power cycling
    What Chemicon series? KZG? KY?
    --- begin sig file ---
    --- end sig file ---
      SM, LXF(?)... a few others, all discontinued. Rubycon primaries, most secondary Chemicon.
      • b700029
        Banned
        • Sep 2010
        • 640
        I see some glue that looks like it's turned brown from heat.
        You might want to remove that.
        Have you found a schematic/service manual and traced out the voltages?
        • retiredcaps
          • Apr 2010
          • 9271
          Try over at eevblog.com forums. They have some people who live to restore old scopes like tekfan. See
          http://www.eevblog.com/forum/index.php?topic=3935.0
            I've so far noticed the -12V rail tends to bounce upwards whenever the trace goes downwards and vice versa. Seems to be the supply for the input amplifier. I'm guessing then the fault is in the power supply...
            I haven't been able to locate a schematic apart from a fee on eBay. Even contacted Agilent directly - no luck.
              Just in case anyone is curious, I eventually got around to removing the power supply and giving it a good look. I'm quite glad because I found a cold solder joint on the -12V output connector! I retouched all the connector joints and it's ran for 3 hours now, no problems. Happy days... This scope is well over 18 years old. Almost as old as me...
                by sam_sam_sam
                03-31-2024, 02:12 PM
                by sam_sam_sam
                07-01-2024, 06:34 AM
              • shamsudeen
                Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                by shamsudeen
                Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                i know that in linear power supply the noise will be very low comparing to SMPS supply....
                07-19-2025, 07:14 AM
              • CMCM
                Russound CA4 Power Supply Repair
                by CMCM
                Hello Everybody,
                Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                The outputs marked 12v and 20v are all measuring only 1v.
                The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                The capacitors physically look clean (no bludgesor leaks) and...
                07-03-2025, 01:12 PM
