Coolermaster RS-550-ACLY "working" w/clicking sound.
  • SIDMX
    • Nov 2010
    • 165
    • Mexico
    PSU has been running perfect for like 5 years then today when i turned ON my PC it started to make this clicking noise, i quickly push the PSU switch to OFF position as i don't want to put components at risk, it sounded (to me) like a small electric arc so i pulled PSU out of the case to check what happened.
    I opened the PSU and turned it on, the clicking starts immediately, and it's coming from or near the "Transformer" labeled API 21639, i tried to record the sound with my cellphone but don't know why the clicking is inaudible in the recording, i'll try later with a camera, already checked 3.3v, 5v and 12v outputs all of them get correct readings in multimeter, i put some light load on PSU by ataching and old PIII motherboard, CPU and RAM, readings stayed the same, i carefully inspected the unit looking for signs of arcing in the area from where the noise comes but everything seems to be ok, so i darken the room as much as i could and turned it on again to see if there was a visible "arc" but i didn't see anything even with the PCB topside down.
    The trasnformer-like must be a PFC coil because there is just one winding and this PSU it's suposedly an Active PFC unit, i ended up removing the PFC coil and all componentes near to it: two film capacitors, the bridge rectifier, primary capacitors and the primary heatsink along with all the "transistors" atached to it, inspected them but no visible signs of spark, burn or arcing were seen.
    I removed the "ground shield"?? (i mean the thin copper sheet around the winding conected to ground in PCB) from the PFC coil but again there where no signs that the winding was arcing to the ground shield.
    So i was forced to do a fast recap to this PSU and put it into my PC recap was done using recycled Sanyo, Rubycon,Chemicon and Panasonic units ...I've unplugged 2 of my 3 HDDs, DVD-RW and pulled out my VGA card to use the IGP to minimize the load ...now that i think about it i'm not sure if it is safer to use K-Mex crap or to put back the coolermaster unit even with that noise.
    Oh by the way it turned out that the coolermaster PSU is really an AC-Bel ATX-400C-A2SNN PSU rated at 400W!! (see last image) i'm not sure if all the "silicons" are the same but the rest of the components sure are) i get the schematic so if needed i could upload it.
    I don't know where it comes or what's causing the clicking noise, so any help, ideas, suggestions or advices are welcome and really apreciated.
  • b700029
    Banned
    • Sep 2010
    • 640
    Re: Coolermaster RS-550-ACLY "working" w/clicking sound.
    Is it sharp or dull clicking?
    • SIDMX
      • Nov 2010
      • 165
      • Mexico
      hi b700029, it's more like a dull clicking, i will solder back all components to record the sound and upload it.
      • SIDMX
        • Nov 2010
        • 165
        • Mexico
        Here's the clicking sound in mp3 format, you may need to turn up the volume.
        I've just measure the voltage across primary capacitors and it shows a fluctuation each time the clicking occurs, it goes down from 405V to 360V.
        • SIDMX
          • Nov 2010
          • 165
          • Mexico
          I haven't had the time to put my hands in this psu and since i already get a psu to replace this one i think I'll leave it for later.
          • Agent24
            I see dead caps
            • Oct 2007
            • 4977
            • New Zealand
            Did you ever find out what was wrong with this PSU?
            My Enermax Liberty 400 just started making a clicking noise, and the PC was still running without any apparent problem - (Of course, I have stopped using it though!)
            I also thought it might be some kind of arcing, but haven't noticed anything.
            -David VanHorn
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Check the diode in the pfc circuit.
              Muh-soggy-knee
              • Agent24
                I see dead caps
                • Oct 2007
                • 4977
                • New Zealand
                Thanks, I have started a new thread here: https://www.badcaps.net/forum/showth...883#post250883 so it's not buried in the bottom of this one.
                -David VanHorn
                • SIDMX
                  • Nov 2010
                  • 165
                  • Mexico
                  Did you ever find out what was wrong with this PSU?...
                  Sorry but I never found the cause of the clicking, this PSU is still waiting for repair and recap.
                  Thank you! I'will try it as soon as I get a replacement diode.
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    Um, Im not saying the diode is at fault, Im saying it could be faulty. If you replace it, and say it was OK, then you have just wasted your time, getting nowhere towards your goal of fixing the PSU.
                    Muh-soggy-knee
                    • SIDMX
                      • Nov 2010
                      • 165
                      • Mexico
                      Thanks again ben7, but it was my bad, i just replied in a hurry and omitted some things in my post.
                      Most components of this PSU are desoldered and stored in a box so when a read your post about the diode I went to the box and check the diode, the reading on my DMM is high resistance in both polarities so i think it's damaged, that's why I said that.
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        Set your dmm to diode check mode. Measuring the resistance doesn't always work to find an open-circuit diode. The meter has to put around 0.7v through the diode to get it to conduct (if its working normally).
                        Muh-soggy-knee
                        • biber
                          • Feb 2015
                          • 104
                          • macedonia
                          I know that this is old post but i will appreciate if you upload schematic for me. Tnx
                          • SIDMX
                            • Nov 2010
                            • 165
                            • Mexico
                            No problem, here you are.
                            • biber
                              • Feb 2015
                              • 104
                              • macedonia
                              TNX again
                              • biber
                                • Feb 2015
                                • 104
                                • macedonia
                                SIDMX do you still have this PSU ? my wife accidentally threw some parts and i cant find the symbols from this parts. I need the symbols of primary, which are attached on heatsink. first two are toshiba k2698 but i dont know the third part on the same heatsink side(it should be an diode), and all three parts from the other heatsink side . TNX
                                • SIDMX
                                  • Nov 2010
                                  • 165
                                  • Mexico
                                  Yes I do, the third one next to the toshiba transistors is D27 = HFA08TB60 it's the PFC diode, on the backside of the heatsink the lone transistor is Q6 = FQPF2N70 this is the 5VSB transistor and the rest are Q3,Q10 = 20N60C3 the PFC MOSFETs.
                                  • biber
                                    • Feb 2015
                                    • 104
                                    • macedonia
                                    SIDMX TNX TNX TNX, finally i repaired this psu and is working perfectly
                                    • B0r1s
                                      Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                                      by B0r1s
                                      PSU - BN44-00878A
                                      Symptoms:
                                      The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                                      A weak clicking sound was coming from the transformer.
                                      Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                                      Progress:
                                      After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                                      01-17-2023, 04:58 PM
                                    • slimmy182
                                      [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                                      by slimmy182
                                      Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                                      I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                                      Looking on google I found this:...
                                      01-14-2023, 11:55 AM
                                    • ChaosLegionnaire
                                      by ChaosLegionnaire
                                      09-13-2022, 09:02 AM
                                    • Solvik
                                      XFX XPS 650w 3XS PSU making Ticking/clicking sound
                                      by Solvik
                                      Hello
                                      i have a older powersupply from XFX that makes this wierd electronic ticking /clicking noise. Its not the fan thats making the sound. See video below. Is anyone familiar with what component this sound can come from?
                                      All voltages are normal....
                                      02-13-2025, 02:43 PM
                                    • nbnb
                                      Vizio VO47L FDHTV30A Picture but no speaker audio, clicking sound
                                      by nbnb
                                      I have a Vizio VO47L FDHTV30A. The picture works well, but the sound only works through the RCA output jacks. The sound does not work through the internal speakers or the headphone jack. The TV has a rapid clicking sound when the tv is on that occurs about 4 times per second. The clicking sound volume is fairly low and is not affected by adjusting the internal speaker volume level. The clicking occurs whether or not I disable the internal speaker through the Vizio setup menu. The clicking only occurs while the TV is on.
                                      Any idea what is causing the clicking sound? Any easy way to...
                                      11-23-2019, 12:03 PM
