iMac 20" PSU 661-3350 - WT7515 Supervisor chip problem
  • Fedguy
    • Sep 2011
    • 7
    Does anyone know whereto buy the dreaded WT7515 chip?
    thx
  • Fedguy
    • Sep 2011
    • 7
    Re: WT7515 chip buy?
    AC/Bel 661-3350
    iMac G5 20"
    First left green LED comes on Logic board but when you push the power button nothing happens. I have 20v and 5v on the connector.
    We traced the voltages on the WT7515 which has the 5v sense in but no 5V out
    • Toasty
      • Jul 2007
      • 4171
      What is the API number on the board? e.g., API 3PC96
      Do you have the datasheet for the chip?
      The chip is a OC/OV/UV supervisor.
      What repairs, if any, have you done to the supply?
      Check Q1 (1P) transistor on the HOT side near the TOPSwitch device. Look for a discolored band running down the middle of the chip.
      Toast
      veritas odium parit
      • Fedguy
        • Sep 2011
        • 7
        Re: iMac 20" PSU 661-3350 - WT7515 Supervisor chip problem
        Has anyone found a supplier yet for the WT7515?
        • Toasty
          • Jul 2007
          • 4171
          Not yet.
          This is why I asked the questions above. You may not have a problem with the chip.
          Toast
          veritas odium parit
          • Toasty
            • Jul 2007
            • 4171
            eBay
            veritas odium parit
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
              Common SPI bios chip programming Questions and Answers
              by SMDFlea
              Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
              A: If you can`t read from it how do you expect to write to it ?.
              Q: Why is my bios chip unreadable ?.
              A: The programmer is faulty or has a worn or broken zif socket.
              The USB cable is frayed,connector pins worn or some other physical damage.
              Not enough amperage or voltage to power the programmer properly.
              Bad...
              09-02-2021, 04:40 PM
            • mich6el
              Imac 2020 a2115 no image after reblays T2 Security chip
              by mich6el
              Hello! Has anyone encountered problems on the Imac 2020 27 inches with a T2 chip? I had to replace 2 T2 chips on two iMacs, the first one was successfully replaced, tested and given to the client. The second iMac after replacing the T2 is flashed, the system is installed through the target mod, it boots into the system, you can hear me tapping on the keyboard, but the image does not display (and to an external monitor​). I reballed the T2 chip, changed the processor, RAM, display. No positive result! My friend said that he had 2 such devices and on both of them, after replacing the T2 boards,...
              04-22-2025, 02:05 PM
            • BMCappelletti
              Asus Chromebox CN62 - wrong chip put on BIOS reader
              by BMCappelletti
              Long story short:
              - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
              - gave the computer to his son a couple years later
              - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
              - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
              (seems like the story was not that short)
              He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
              01-08-2025, 07:27 PM
            • Troystain
              Help EZP2023+ updated chip database for w25q256jveq?
              by Troystain
              Hello, anyone here have updated ezp2023+ chip database in .dat file format.
              I need to add w25q256jveq chip but I do not know what data should I type.
              I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
              The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
              11-25-2024, 12:53 AM
