Benchtop Power Supply troubleshooting
  • bw1
    • Sep 2010
    • 172
    First, I should mention that I don't (yet) even have the unit that this powers, so I can't do much testing at this point. I'm told it won't power their testing unit.
    Unit is rated at 12V/6A output.
    By the looks of it, and my limited knowledge of power supplies, the transformer feeds a full-wave rectifier. Measurements at rectifier are the following:
    AC-IN: 15vAC (approx)
    DC-OUT: 19vDC (approx)
    Does this look correct so far?
    The only measureable output at the front is two pins that read around 3vDC, but for all I know the 12v output needs a trigger to turn it on.
    Any suggestions before I can get the actual unit that this powers?
    The actual circuitry on the board looks very simple. I'm just not familiar with the functions of each component at this point. The mess at the back AC-IN is a switchable 120/240v, set correctly.
    Thoughts?
  • sjwilson122
    • Jul 2011
    • 5
    Re: Benchtop Power Supply troubleshooting
    With no load those voltages look ok. The bridge could be failing under load, but doubtfull. You could check by pulling the red and black lead from the bridge and use clip leads to connect a heavy load (maybe car headlight) and check voltages. Low beam headlight is about 35 watts, high beam about 55 watts and with 12v/6a you should be able to do 72 watts. You are probably correct about the trigger. In picture two, the pot on the left named "shut down" is probably the adjustment for some type of comparator circuit that shuts the supply down if the expected voltage is out of spec.
    • Toasty
      • Jul 2007
      • 4171
      http://cgi.ebay.com/ebaymotors/ws/eB...m=230641739186
      Is the TO-3 cased item a transistor or voltage regulator? Also, a better shot of the (cleaned up) board to see if there are other components would be helpful. Can you remove it from the case and give a top-down and solder side pictures?
      veritas odium parit
      • bw1
        • Sep 2010
        • 172
        Removing the board revealed more. (I know, I know. Should have seen it. It was hidden under the one big cap and not really visible.)
        Looks to be a fried 5v regulator? So, is that likely the cause of the problem, or just a symptom?
        • Toasty
          • Jul 2007
          • 4171
          mmmmmm......... Toasty!
          It's an adjustable voltage regulator, LM2931CT by Motorola.
          2.7v to 29.5v
          "The LM2931 series regulators are designed with many protection features making them essentially blow–out proof."
          OOPS!!
          Also, on the solder side there's a 78L05, SO-8 package, 5v regulator.
          veritas odium parit
          • bw1
            • Sep 2010
            • 172
            Replace it with identical chip and try it out? Or should I be testing/checking anything else before doing that?
            • Toasty
              • Jul 2007
              • 4171
              Prior post updated.
              Depending on how it's in the circuit, I would start by checking the power transistor. It's probably okay because the (2) 0.22Ω resistors look undamaged. It appears to use the 2N5884 to boost the current, as the LM2931 is only good for 100mA or so.
              Check the other transistors as well. Q2 and the 1P's on solder side.
              Also, if the filter caps have gone weak, they could be allowing a lot of ripple into the circuit.
              veritas odium parit
              • bw1
                • Sep 2010
                • 172
                This has been waaaaaay on the back burner for a while now. I haven't had time to troubleshoot any more with the circuits themselves, but since the adjustable regulator was obviously fried, and very cheap, I do have a replacement part here for that.
                If there are other transistors that are bad, or other components, is the probability that it just wouldn't work, or is there a chance that it would output too high and damage equipment hooked up to it?
                If it just will work / not work, I'm just going to try replacing the obviously bad part first. If it could output high because of something else, I'd take more time on it and see. It's not a very expensive power supply, and I don't have a lot of time for it right now.
                Any thoughts?
                (added: about the caps, they all look fine visually. further than that, i don't have the equipment to test/verify them.)
                • shamsudeen
                  Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                  by shamsudeen
                  Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                  I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                  i know that in linear power supply the noise will be very low comparing to SMPS supply....
                  07-19-2025, 07:14 AM
                  by sam_sam_sam
                  03-31-2024, 02:12 PM
                • dragon3x
                  >>> Troubleshooting Delta Power MAX 500ATX ATX power supply
                  by dragon3x
                  Hi, this is for troubleshooting and, hopefully, repairing a Delta Power psu
                  that is still quite new, as it worked OK for some months until it failed.
                  At the time I was not into power supply electronics; it was put
                  aside and a new power supply installed inside the computer. Also at the time
                  power supplies were half the price of today's.
                  On the PCB there are a D339 and 7500B chips.
                  I have found that schematics with these 2 chips (see included file).
                  Does it represent the actual circuit of the MAX-500ATX, I cannot tell.
                  Some measurements,...
                  06-05-2024, 03:34 PM
                • navagator
                  Hitachi Power Supply Unit Interchangeability
                  by navagator
                  I have a Hitachi 57F710E rear projection set with a bad power supply board. I've tried to fix it with help from this forum as well as another one, but without success. Today I found a Hitachi rear projection set for sale on Facebook that looked just like mine. After contacting the seller I found out it was a 51F510. According to the service manuals my set uses a HA01312, POWER UNIT DP4X-DM_24W and the 51F510 uses a HA01313, U901, POWER UNIT DP4X_24W.
                  Does anyone know if these 2 power supply boards are interchangeable?
                  Thanks.
                  01-08-2024, 07:53 PM
                • MtnManMike
                  Samsung UN75J6300AFXZA LCD TV Power Supply Troubleshooting
                  by MtnManMike
                  I'm hoping to get some help figuring out how to troubleshoot this power supply board. The television is a Samsung UN75J6300AFXZA, version no. UH03. The power supply board has two model numbers on it, L75S1 and BN44-00723C. As far as experience level, I'm familiar with recapping boards in terms of safely going through the soldering motions, choosing suitable replacement parts, and so forth, but as far as understanding the various functions of each part of these TV power supply boards, I am a rank beginner.
                  When I plug the TV in, the screen flashes on and off and...
                  07-23-2022, 06:43 PM
