Capacitor source.
  • lifeatthesharpend
    • Jul 2011
    Capacitor source.
    I'm looking for a source of new capacitors in the uF to 100's uF range with a voltage rating of 1000 V or higher. Any suggestions?
    Life.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Capacitor source.
    Where are you?
    Mann-Made Global Warming.
    - Dr Seuss
    • lifeatthesharpend
      • Jul 2011
      I'm in SoCal
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Digikey.com or Mouser.com
        - Dr Seuss
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16959
          Yup, that's nothing I'd have around.
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • MORETTIGIAN
            by MORETTIGIAN
            Title:
            Description:
            Procedure performed:
            - Removed backplate
            - Reapplied thermal compound
            - Reassembled card
            09-18-2025, 12:14 PM
          • chth96
            Is it no harm to replace with capacitor without ripple current rating?
            by chth96
            When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
            Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
            But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
            Rubycon YK DataSheet (b...
            04-19-2024, 05:19 AM
          • Agent24
            Dick Smith Q-1760 linear power supply filter capacitor question
            by Agent24
            I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
            It has at least one problem.
            The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
            I have already ordered a replacement potentiometer, so that's not an issue.
            Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
            All are CapXon...
            10-21-2025, 05:39 PM
          • Prolog
            by Prolog
            12-01-2024, 08:27 PM
          • Adenitz
            Explanation of capacitor rating
            by Adenitz
            I'm reading an article about the "capacitor plaque" in early 2000s and I have found one sentence I cannot understand.
            The normal lifespan of a non-solid electrolytic capacitor of consumer quality, typically rated at 2000 h/85 °C and operating at 40 °C, is roughly 6 years. It can be more than 10 years for a 1000 h/105 °C capacitor operating at 40 °C.
            What this 2000h or 1000h means? Why 1000h capacitors have longer life span?
            12-26-2022, 12:36 AM
