Converting 110/220V supply to autovolt
  • rogfanther
    • Jul 2006
    • 458
    • Brazil
    I have a DPS-250AB with burnt, charred toroid, and while it maybe can be rewound, it will take some time, and the client decided he needs the machine.
    I´ve explained the situation, and they are ok with me substituting the insides of the old supply.
    I´ve located some small ones, that fit inside the dead one, but the original are automatic voltage selection ones, and the ones I found have the 110/220V switch. I cannot trust nobody will use it in a 220V outlet.
    So, have anybody managed to transform some of these selectable supplies in auto-selectable ,dual voltage or however it is called ? I´m ok if I have to switch the input caps, or something like that. Also , the learning experience would be good.
    Thanks for the help.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Converting 110/220V supply to autovolt
    You either need an active PFC stage like the old supply had, or some type of line sensing circuitry that switches a relay. The circuitry isn't exactly trivial to make, and it's not worth the effort.
    A working TV? How boring!
    • rogfanther
      • Jul 2006
      • 458
      • Brazil
      Hmm, ok, thanks. I am also spending too much time trying to be creative with this psu ....
      Will try to fix the toroid, and also measure if it is possible to cut a hole in the casing for the switch ... whatever can be done first...
      Thanks again .
      • 370forlife
        Large Marge
        • Aug 2008
        • 3113
        I actually have an old ATNG unit that does sense the voltage input and changes itself accordingly, no PFC either.
          by sam_sam_sam
          03-31-2024, 02:12 PM
          by sam_sam_sam
          07-01-2024, 06:34 AM
        • shamsudeen
          Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
          by shamsudeen
          Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
          I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
          i know that in linear power supply the noise will be very low comparing to SMPS supply....
          07-19-2025, 07:14 AM
        • JimBanville
          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
          by JimBanville
          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
          09-13-2023, 07:21 AM
