10/100 Ethernet Hub Dead
  • Solder Boy
    • Nov 2006
    • 178
    I thought I would come here and pick your collective brains on this power supply from a big internet hub. Main issue is that it is dead won't turn on.
    Here are my initial findings:
    Main Cap= 168 VDC
    Bridge Rectifier 123.5 VAC
    Toshiba K2611 DC-DC Converter 168.3 VDC
    Transformer - 169.7 VDC
    The two Schottkey Diodes behind the transformer no voltage
    Q7 No Voltage
    Q8 No Voltage
    Q2 00.2 VDC
    I checked for voltages at the ATX plug found none.
    Given that there essentially is no voltage on the output side.. would my gut instinct be correct that the Toshiba DC-DC converter has gone south? It has VDC coming into it but I don't think it's outputting anything.
    I've got two of these to repair.
    Thanks in advance!
    www.bcrelectronics.ca
  • Krankshaft
    • Jan 2007
    • 2328
    Re: 10/100 Ethernet Hub Dead
    When my hub power supply went the PWM IC died replacing it fixed it.
    Check the startup resistors on the PWM for an open. If they are okay check for a drive waveform to the base of the switching transistor.
    If there is no drive and external components around the PWM look okay including the feedback circuits. Replace the PWM IC.
    This is where having an oscilloscope is the difference between gathering the evidence and replacing a part and hoping .
    • Solder Boy
      • Nov 2006
      • 178
      I hear ya about the "cilly" scope but it's not something I can afford at the moment. Last I looked even used ones were excessively expensive.. don't do enough repairs to justify the cost.
      My next guess would have been the IC as you mentioned.
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        There's an 8-pin IC on the primary side. What part number is written on it?
        It's possible that the stat-up cap (likely the one close to the MOSFET on the primary side) could be bad. Or it could be that the auxiliary winding rectifying diode is shorted.
        • Agent24
          I see dead caps
          • Oct 2007
          • 4979
          • New Zealand
          Shouldn't that be AC? Transformers don't work on DC...
          If you are measuring DC (I assume on the primary side) wouldn't that mean the switcher isn't switching?
          -David VanHorn
          • rogfanther
            • Jul 2006
            • 458
            • Brazil
            I suppose he measured that in the transformer after the toshiba ic. As it is after the bridge rectifier, there it would appear as DC pulses,
            • Solder Boy
              • Nov 2006
              • 178
              I'll get back to you later about the IC part number.. all the caps are good.. checked them all with my ESR and Capacitance meter.
              @Agent yes it was DC I measured not AC.. will check for AC and report back.
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                Measuring AC at the transformer primary is pointless. Why? - because the signal is high-frequency square wave and a regular multimeter will not measure it properly. If you have a cheap multimeter, this may even destroy it.
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4979
                  • New Zealand
                  I guess you would need an oscilloscope there instead then?
                  -David VanHorn
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    You could do that, but then you will most definitely need an isolation transformer. Everything on the primary side has a hot ground, so if you touch anything on there with a grounded object, you'll probably get nice fireworks .
                    Rather than checking AC at the primary, it's usually easier to just measure the voltage going to the PWM IC, then verify from its data sheet whether the voltage you measured meets the IC's threshold.
                    • Manuel S.
                      Lenovo Yoga 720-15ikb (LA-E552P): DEAD - strange voltage on 5V buck converter
                      by Manuel S.
                      my Lenovo 720 is dead. :-(
                      I guess i have found an issue on the 5V buck converter (**BAC7NH** from Silergy (also called SY8288C 5V)) but i am not completely sure so i want to ask here for some hints.
                      Here is a Schematic of the IC: https://prom.ua/p1498216381-sy8288c-...ac-bacxxx.html
                      When i attach the supply 19V, i only have 1.8V on the OUT (it should be 5V). The IC is getting hot.
                      The EN1 is completely off 0V, EN2 show 1.5V.
                      If i inject 5V on the EN1 the OUT goes up to 2.6V (but never reach 5V).
                      BS seams SHORT to the OUT....
                      03-14-2024, 05:17 PM
                    • playit
                      ps/2 port keyboard dead ? p5ql pro / ethernet cable light
                      by playit
                      my system is p5ql pro asus mobo , logitech keyboard ps2 keyboard (more than 10 years) .
                      my place use to get some power drip for a second ,at that time , pc shuts and restarts itself , it dint cause any problem till now , once or twice i noticed , i am not sure if it was exactly at power drip time or normal time - both keyboard and ethernet lan stopped working , the keyboard would lose power i mean led lights-num lock caps lock would not stay on , no light at etherbet cable too..then i would restart the pc - then its all good .
                      few years back ps2 mouse stopped working, but ps2...
                      12-23-2024, 06:05 AM
                      Lenovo ThinkPad T490s + Ethernet Extension Adapter Gen 2 Notebook T Specification for Upgrade or Repair
                      This specification for the Lenovo ThinkPad T490s + Ethernet Extension Adapter Gen 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T490s + Ethernet Extension Adapter Gen 2 boardview and T490s + Ethernet Extension Adapter Gen 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                      09-06-2024, 08:58 AM
                    • madan1
                      Cisco catalyst 2960c POE
                      by madan1
                      Hello everyone.
                      Got a catalyst 2960 from the usual scrapyard - ebay.
                      It is stuck in bootloop and the power supply is missing the 3.3v rail. (+12V, -53V, +3.3V)
                      Some green moisture crystallization on mainboard, which cleared very well with IPA and visually there is nothing rusted or gone.
                      Still working on the PSU to get the 3.3v rail back (waiting for parts), but for now I'm using an external buck converter board hooked up to the 12V rail ( by the way, the switch seems to be working with only 12V ).
                      The switch fails to boot due to the following POST error:...
                      12-19-2024, 09:34 AM
