SMPS: which cap should be hi-ripple?
  • baritonomarchetto
    • May 2011
    • 8
    A n00b question, i know, but reading how a switch works and considering that almost all the components are subject to ripple currents (peak currents coming from the alternate component of the "wall" juice, right?) should i conclude that its mandatory (or at least highly suggested for long life) by using ALL high ripple graded capacitors in my switch? Are there caps in the switch that could be kept low-ripple cheap crappy caps ?
  • Gianni
    • Jul 2008
    • 681
    • Italy
    Re: SMPS: which cap should be hi-ripple?
    Well on SMPS (SWITCH MODE POWER SUPPLY) it is important to use always good caps with low ESR and high ripple current.
    All topologies need good caps: fly-back converter, buck converter, boost converter, resonant converter, half bridge, full bridge, forward, step down and step up converter...
    Usually only the big caps on the input side after the rectifier bridge (input freq. 50~60Hz) can be general purpose or no LOW ESR; today most SMPS have the Power Factor Correction so almost all caps are LOW ESR.
    General purpose caps can be used on linear regulators where the current ripple is very low or other circuit with no high frequency current.
    Anyway it is different to use "general purpose caps" instead of "crappy caps", I should avoid the last ones if I want a reliable circuit
    Ciao
    Gianni
    "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
    H. J. Brown
    • baritonomarchetto
      • May 2011
      • 8
      Thank you very much
      ciao
      • Longbow
        • Jun 2011
        • 623
        In a SMPS, any capacitor or diode that operates at the switching frequency must be a high frequency part. Typcially, the secondary rectifier diodes and filter caps all have to be high frequency types. The mains filter cap obviously does not have to work at the switching frequency.
        Is it plugged in?
          ISL6556ACB ISL6556ACBZ ISL6556ACR ISL6556ACRZ PWM Controller Datasheet
          Optimized Multi-Phase PWM Controller
          with 6-Bit DAC for VR10.X Application
          The ISL6556A controls microprocessor core voltage
          regulation by driving up to 4 synchronous-rectified buck
          channels in parallel. Multi-phase buck converter architecture
          uses interleaved timing to multiply channel ripple frequency
          and reduce input and output ripple currents. Lower ripple
          results in fewer components, lower component cost, reduced
          power dissipation, and smaller implementation...
          11-05-2024, 03:10 PM
        • dkneyle
          Onkyo DX-V500 Laser Disc Player - weird SMPS fault
          by dkneyle
          This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
          Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
          02-01-2022, 02:08 AM
        • shamsudeen
          Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
          by shamsudeen
          Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
          I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
          i know that in linear power supply the noise will be very low comparing to SMPS supply....
          07-19-2025, 07:14 AM
        • chth96
          Is it no harm to replace with capacitor without ripple current rating?
          by chth96
          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
          Rubycon YK DataSheet (b...
          04-19-2024, 05:19 AM
        • Antonynl
          What are typical ripple voltages on a laptop motherboard?
          by Antonynl
          I have here a HP pavilion hp 15-cs2975nd with a 1.095v power supply that is driven by a FDMF3035. I do see about 80mV of ripple on my scope. I searched through the datasheet to find possible values of the ripple but I don't understand the datasheet well enough.
          So I have two questions:
          1) what is the typical ripple voltages of gpu/cpu on a laptop or pc mobo?
          2) what would be the max ripple of a FDMF3035 that drives an output of 1.095V?
          Would be nice to have a rule of thumb of say a percentage of the supply voltage to be an acceptable ripple voltage....
          12-09-2022, 06:51 AM
