Rocktron velocity 300 Power supply question
  • amelbye
    • 46
    • Norway
    Hey, I have a problem with a rocktron velocity 300 power amplifier (the original 2 unit version from the 90s). I posted here since I believe the problem is power supply related.
    It breaks a lot of fuses on power-up, and it makes loud noise whenever I plug or unplug something in the same room.
    I had a local tech look at it (for blowing fuses). He couldn't find anything wrong with it and said the only thing I could do was start using a slightly bigger fuse, which is what I've done now for the past 6 years.
    However, I'm sure there has to be something wrong at the power input stage for it to make the noises it does whenever there is a fluctuation in line voltage.
    Or maybe it's a design flaw. If so, how can I modify the unit to fix this? (I'm on 230V)
    I've attatched a full schematic of the unit.
    Best Regards
    Audun
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Rocktron velocity 300 Power supply question
    The schematics are unreadable, please post higher resolution versions. But regardless, it sounds like the transformer of this unit does not have soft start so it draws a large current upon startup till the core magnetizes fully.
    You need a soft start module. You can either buy or build one. It's not too sophisticated - a power resistor and a relay bypassing it. The timing aspect of things (turning the relay on to bypass the resistor for normal operation) can be handled by a 555 timer.
    A working TV? How boring!
    • amelbye
      • 46
      • Norway
      that's strange, I'm sure I uploaded gif files of adequate resolution, not jpegs... ah I see, there's a very small max resolution for gif attachments on this forum. Even the max resolution for jpegs is a bit small for these schematics.
      Here I've uploaded them to my own site:
      I guess a softstart should get around the problem, but don't you think there's something wrong causing it to draw so much current? It breaks the fuse about 30% of the times I turn it on, I'm sure most of these amps do not...
      • gtrmann1
        • Nov 2011
        I have extensive experience with the Rocktron products and have a few tips that may help...
        1.) Make sure the volume of both channels regardless of bridged/stereo selection is completely down before power up.
        2.) Make sure your input volume from your last unit going into the amp is muted. You want to avoid any kind of "popping" as the circuit receives that "spike" as an overloaded signal and ping goes your fuse(s).
        3.) Check your cables! Make sure you are using speaker cables for speakers and a balanced or instrument cable for your amp inputs. This is usually the problem. Most guitar players will just use an instrument cable going into their speaker cabs...huge No No! Everytime I have encountered a fuse blown from my 300 it was a bad speaker cable. They don't last forever!
        4.) Power up your amp LAST, shut it down FIRST always.
        I am surprised that placing a larger value fuse works and did not overload your coils. I would check this list and attempt to go back to the standard fast blow fuses.
        Anyway, sometimes it's the simple things, and Rocktron can be very touchy with input signals. Good Luck!
        Tim
        • amelbye
          • 46
          • Norway
          Thanks for your reply!
          1) I haven't tried this, however I generally keep them low when I power up
          2) This would only make a difference if I powered on the velocity before the preamp. I always turn on the power amp last, hence it won't take much notice of any voltage spike from the pre.
          3) Cables are fine. In fact, the amp even blows fuses with nothing connected at all.
          4) That's what I do.
          I guess using a larger fuse does put the coils at risk. However, as long as there's not anything seriously wrong with the unit, even running the thing unfused should be safe. And illegal of course.
          I'm pretty sure this has nothing to do with input signals. It only blows fuses at power-up. Never while in use.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            Inrush current. Some thermistors in series with the AC input will help, a full-blown softstart circuit may not be needed. Try two NTC thermistors in parallel, recovered from ATX PSUs.
            • amelbye
              • 46
              • Norway
              ah, such a simple solution!
              do I place the thermistors before or after the fuse though?
              The fuse is in the power plug on this device.
              And why do I need 2 thermistors?
              I have a few AT power supplies in the garage, I'm sure I'll find some in there. Thanks
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                One may not be enough to keep that big toroid happy, cheap PSUs tend to use underrated parts so put two in parallel to ensure they don't blow up. Heck, some units even omit them altogether... Especially the noname specials labeled at 3x their real power. It's recommended to mount them after the fuse. Also keep them away from sensitive parts as they run hot.
                  by sam_sam_sam
                  03-31-2024, 02:12 PM
                  by sam_sam_sam
                  07-01-2024, 06:34 AM
                • JimBanville
                  Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                  by JimBanville
                  The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                  Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                  I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                  I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                  09-13-2023, 07:21 AM
                • Gjackson
                  Air-conditioning unit power supply failing to power up
                  by Gjackson
                  Hi all, I managed to narrow down which PCB was causing my Haier AC to throw out an E7 error code (E7 indicates that the indoor unit and outdoor unit cannot communicate). I found that the outdoor unit power board which gives 5v and 15v to the outdoor unit module board fails to fully power up.. The power Led starts to fade in incredibly slowly and the 5v and 15v power buses jump around like crazy and never reach their required voltage. I unplugged the module board from the power board and the power board powered up fine! It had a steady 5v and 15v out and the power LED came on instantly and Bright....
                  01-08-2022, 09:24 AM
