Add the missing 4 pins?
  • bigbeark
    • Jan 2010
    • 661
    I have an IBM Thinkcentre Mini-Tower. It's old but very solid, and the current mobo needs a recap (Duron 1000). I also have an ASUS Core 2 MATX board that would fit except that the IBM PSU is 20-pin and the ASUS wants 24-pin.
    The ASUS is a low-end board running a single-core Celeron. I think the IBM PSU would have enough juice to operate the ASUS.
    Can I take the extra power from one of the spare Molex connectors. I could use a 24-to-20 pin adapter and splice into it.
    Sounds like a bodge, but don't want to buy a new SFF PSU, and might not even fit the IBM case.
    Your comments appreciated!
  • 370forlife
    Large Marge
    • Aug 2008
    • 3113
    Re: Add the missing 4 pins?
    The extra 4 pins are just 1 12v, 1 5v, 1 3.3v, and one ground. Most 24pin boards can run with just a 20pin installed.
    • Scenic
      o.O
      • Sep 2007
      • 2642
      you only need a 24pin psu if you're running power hungry PCI Express graphics cards.
      if you're using low end PCIe graphics or onboard video, it doesn't matter.
      be careful about the PSU though. old systems (socket A era, like that Duron 1GHz) are very 5V-heavy (more amperage on 5V), while newer systems (including all Socket 775 boards) get their CPU power off 12V instead.
      if the PSU has at least 8A on 12V, and the Celeron is a Core 2 based one (Celeron S4xx) it should work fine.
      if it's an older netburst (P4 based) celeron (D3xx), it would easily overload the PSU..
      edit: same thing basically goes for the 12V "P4" plug.
      you only need the 8pin EPS plug if you're running high-end CPUs or overclock to the max.
      the standard 4pin plug is enough for most CPUs..
      (i'm actually running a Core 2 Quad Q6600 overclocked from 2.4 to 3.2GHz on a 4pin 12V plug. no probs whatsoever)
      • japlytic
        • Oct 2005
        • 2086
        Many high-power PCI Express graphics cards have a 6-pin +12V connector on them. Most of the power is drawn from this 6-pin connector.
        • Scenic
          o.O
          • Sep 2007
          • 2642
          yeah, but they also rely on that 75(?)watt PCIe spec.
          especially the "higher end" cards which don't have the 6pin 12V plug (9800GT Green Edition for example).
          as long as you're using really low end cards (7300GT, 8500GT, 9400GT .. stuff like that) you don't really need a 24pin PSU.. much less when using onboard video.
          if in doubt, there's still stuff like this
          http://cgi.ebay.com/190498296403
          • khabib
            ASUS STRIX G531GT MISSING PM_SLP_SUS#
            by khabib
            Hello guys i have ASUS laptop that power on but can't switch ons , i trying using power sequence and last missing PM_SLP_SUS# .
            here what i measure already:
            EC_RST# 3.3V
            SRTCRST# 3v
            +3VA_RTC 3V
            RTCRST# 3V
            ME_SusPwrDnAck 0V
            AC_PRESENT 3.3 V
            AC_IN_OC# 0V
            PS_ON 3,3V
            +3VA_DSW 3.3V
            DPWROK_EC /R 3.2V
            PM_BATLOW# 3.3V
            SM_INTRUDER# 2.8V
            PM_SLP_SUS# -----> MISSING VOLTAGE ( but sometime this voltage is present )
            THat is can confirm PCH relate issue...
            05-28-2024, 01:30 AM
          • gurj1979
            Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
            by gurj1979
            Hey guys.
            Need help with this one.
            Fan not spinning due to missing PWN Fan signal.
            Also 5 seconds from powering up it freezes, unless in BIOS.
            But as soon as Windows starts to load, it will freeze.
            CPU is COLD / Room temp when it freezes.
            I've replaced the CPU, same problem.
            Replaced SIO/KBC IT8987e and reprogrammed - same problem.
            Replaced fan - same problem.
            Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
            Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
            08-19-2024, 05:22 PM
            ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
            This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
            09-07-2024, 02:50 AM
            ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook CX1 Specification for Upgrade or Repair
            This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
            ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
            This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
