Delta proprietary chips? What are they?
  • larrymoencurly
    • Oct 2004
    • 960
    Many Delta PSUs use 16-pin chips labelled DNA1001D and DNA1002D. Does anybody have the standard part numbers for these or the pinouts? The DNA1001D is always found in the high voltage section, the DNA1002D in the low voltage section. Doom.com lists these as Hitachi parts, but I can't figure out which Hitachi part numbers match. Deltas that use these chips also have a standard LM324 op amp chip that handles overvoltage detection and maybe some other things.
  • PeteS in CA
    • Aug 2005
    • 3583
    • USA, Unsure of Planet
    Re: Delta proprietary chips? What are they?
    I worked for Delta 1998-2001 doing tech support. Both ICs are proprietary ASICs. The DNA1001D has a power factor correction controller (possibly similar to a UC3854) and a PWM (similar to the UC3842) in one IC. The DNA1002D integrates several "housekeeping" functions (I forget which ones specifically) such as current limit, output sequencing, and OVP (the LM324 may be used as the main error amp and/or magamp controller and/or to monitor more O/Ps for OVP than the ASIC can). At the time I was with Delta, these ASICs were usually used in more expensive (than 200W-250W PC P/Ss, which were being sold to Apple, Dell, et al for $12-$15 US).
    mod comment : certainly coudn't get a better response than that, thanks Pete!
    PeteS in CA
    • larrymoencurly
      • Oct 2004
      • 960
      Thanks, Pete, great answer!
      • japlytic
        • Oct 2005
        • 2086
        I have an application circuit from a Delta ATX PSU (about 150W):
        Pin 1 is the Power Enable Output (open collector)
        Pin 3 is the Power Good output (open collector)
        Pins 6 and 12 apparently have something to do with the oscillator frequency.
        Pins 4 and 7 are a bit uncertain; feedback change delay or soft starting?
        Pin 5 is the Power Enable Input (turns the supply on)
        Pins 12, 13 and 15 - a bit unsure; something to do with feedback of a supply other than +5V, +12V, -12V?
        Pins 2, 9, 10, 11 and 16 are self-explanatory.
        I cannot find anything about the DNA1002 providing current limiting and output sequencing.
        • oyovera
          • Aug 2010
          thanks for the IC's circuit. It will help me alot.
          • Krankshaft
            • Jan 2007
            • 2328
            The DNA1001 and 2 are the same ICs used on the original Delta brand Xbox power supplies.
            • Zoli
              • Aug 2010
              Many thanks for the circuit and description.
              I hope this gives me help.
              • jaberkhan
                • Dec 2010
                Re: DNA1001 Ic Data Required. What are they?
                Ic data Search DNA1001 which used in dell power Supply
                • pcdocstar
                  • Nov 2010
                  "The DNA1001D has a power factor correction controller (possibly similar to a UC3854) and a PWM (similar to the UC3842) in one IC."
                  That guy is mistaking! I spent few days to make schematic diagram for each of them.
                  He explains about DNA1005A. Here is schematic for 1005D:
                  http://www.rom.by/comment/256829
                  DNA1001D don't have any APFC! Here is diagram for 1001D
                  http://www.rom.by/comment/256326
                  So far I didn't get any power supply with DNA1001DL in SOP-16. That one is strange...
                  • carl 169
                    i did some additional investigation on the delta ic DNA1001
                    one missing wire from the drawing of the previous comment there a missing wire from pin 8 of dna1001 to IC2 pin 4 ( opto) need to be added tio the schematic
                    pin assignement ( what i found )
                    #1 could be slope compensation or current sense
                    #2 gnd
                    #3 output mosfet drive
                    #4 ?
                    #5 5V ref output
                    #6 osc (need a capacitor to gnd and a resistor to 5V ref to set the frequency)
                    #7 gnd
                    #8 voltage feedback in
                    #9 soft start ( larger capacitor make power supply longer to ramp out the output)
                    #10 shutdown (0V =power suppling running 5V = shut down)
                    #11 ?
                    #12 ?
                    #13 ?
                    #14 ?
                    #15 could be slope compensation or current sense
                    #16 gnd
                    Carl
                    • japlytic
                      • Oct 2005
                      • 2086
                      Pin 15 is current sensing and Pin 4 is the common of the 200/250V primary electrolytic pair.
                        MSI Delta DELTA 15 A5EFK-008 Notebook 15 Specification for Upgrade or Repair
                        This specification for the MSI Delta DELTA 15 A5EFK-008 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the DELTA 15 A5EFK-008 boardview and DELTA 15 A5EFK-008 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-07-2024, 03:40 AM
                      • ugamazing
                        Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
                        by ugamazing
                        I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
                        08-31-2022, 07:34 AM
                      • Junkrepair
                        Calculating ESR from tan delta -- tan delta's dependence on capacitance
                        by Junkrepair
                        I'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
                        I found this nice little description of the conversion:
                        Calculating capacitor ESR from Tan(delta)
                        https://forum.digikey.com/t/calculat...-from-tan/2633
                        It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...
                        06-12-2023, 02:45 PM
                        MSI Delta 15 A5EFK-081AU Notebook 15 Specification for Upgrade or Repair
                        This specification for the MSI Delta 15 A5EFK-081AU Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 A5EFK-081AU boardview and 15 A5EFK-081AU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                        09-07-2024, 06:11 AM
                        MSI Delta 15 A5EFK-046UK Notebook 15 Specification for Upgrade or Repair
                        This specification for the MSI Delta 15 A5EFK-046UK Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 A5EFK-046UK boardview and 15 A5EFK-046UK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                        09-07-2024, 05:50 AM
