old ibm-6043 switching on?
  • tukidid
    • Jan 2011
    • 11
    how do you switch it on- it has neither computer switch wires(black,brown,blue,white)nor the green one
    tnx
  • Wizard
    • Mar 2008
    • 2296
    Re: old ibm-6043 switching on?
    does power supply have thin 3 wire into small black connector?
    Use meter on ohm to find ground to metal power supply case and find 5V standby supply then the last wire is power on wire. Short this to ground wire to turn power supply on.
    Cheers, Wizard
    • tukidid
      • Jan 2011
      • 11
      the pinout of the ibm pc300gl mbd connector is
      Connector Location Pin 1 Pin 2 Pin 3 Pin 4 Pin 5 Pin 6
      P1 System Board PWRGOOD +5 V +12 V -12 V GND GND
      P2 System Board GND GND -5 V +5 V +5 V +5 V
      P3 3.5" Diskette Drive +5 V GND GND +12 V – –
      P4 DASD +12 V GND GND +5 V – –
      P5 1 DASD +12 V GND GND +5 V – –
      P9 2 System Board +5 V CONTROL GND – – –
      P10 Riser 3 V +3.3 V +3.3 V +3.3 V GND GND GND
      P11 System Board 3 V +3.3 V +3.3 V +3.3 V GND GND GND
      P12 LAN +5 V CONTROL GND – – –
      but connecting pin1 to pin5 or earth did nothing
      • tukidid
        • Jan 2011
        • 11
        thanks you probably refer to P9(or p12 -pc could be woken up from lan)
          03-31-2024, 02:12 PM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
          DVR camera recorder switching power supply capacitor failure really
          These cheap non brand capacitors at it again
          Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
          Well at least I have the cameras back on line I to try the...
          01-22-2022, 06:28 PM
          After all of...
          07-13-2024, 08:14 PM
          07-01-2024, 06:34 AM
