Question on ESR and Capacitor Selection.
  • TheLaw
    • Jan 2011
    • 477
    I've been trying to figure out this ESR thing for a while now, but it's not making too much sense. I know that 0 ESR would be a perfect capacitor with no resistance whatsoever. But we all (most of us), know that all capacitors, ceramic or electrolytics, have resistance.
    What I don't understand is how this affects a power supply or a circuit.
    If you have less ESR, how does this affect a power supply?
    I'm trying to build a stable linear power supply and although I know that certain components should be low ESR, and I know how to achieve that, I don't understand what ESR itself actually does.
    Also,
    Usually the main big filter cap before the regulator IC does NOT have to be low ESR. On PSUs with PFC circuits, the bulk capacitor does not have to be low ESR. Why is this?
    I'd appreciate any answer. Big or small.
    Thanks.
  • Slakky
    • Nov 2009
    • 15
    Re: Question on ESR and Capacitor Selection.
    You can type all of these terms into Wikipedia and get some answers. ESR is Equivalent Series Resistance, which is the same as a resistor in series with the capacitor. The exact value of the resistor changes with frequency though, and it's dominated by tan(delta) at low frequency and Z at high frequency. If you type "loss tangent" into Wikipedia, you can see an explanation of the relationship.
    Usually when they say "Low ESR" caps, they mean "fit for high frequency use", which is basically any cap that bothers to list Z@100kHz in its data sheet. Most of the time general purpose caps are just a cost cutting or space saving measure, unless the circuit is built with a specific high ESR in mind like with LDO regulators.
    The reason why you have to have low ESR caps on the secondary side of an SMPS is because the switching frequency noise they have to filter out is around 25~100kHz, so they have to perform well at that speed. The big primary cap doesn't have to be low ESR because it's just providing hold-up time at 50~60Hz. The same goes for the big cap before the regulator in LM317 and LM78xx/79xx circuits.
    • Trinite
      • 143
      From what I've understood, the higher the ESR, the longer a capacitor takes to charge and discharge. Which means a high ESR capacitor works fine for simply storing electricity, but would do poorly for filtering, since the slow charge/discharge limits its ripple capacity. The effect of ESR on ripple capacity would climb proportionally with current frequency, i.e. the ESR of a capacitor has a more pronounced effect the higher the frequency of the current you are filtering.
      • TheLaw
        • Jan 2011
        • 477
        But the capacitors after the LM78XX regulator shouldn't be low ESR? This is what has been confusing me. They technically aren't switch-mode converters but they do function similarly in theory.
        And in regards to low drop out regulators, you want higher ESR?
        Thanks for the detailed answer.
        • TheLaw
          • Jan 2011
          • 477
          Simply put! Thank you.
          • Slakky
            • Nov 2009
            • 15
            No, the LM78xx don't care what you put after them. The caps after a switching regulator are part of a pi filter (Wikipedia that) which turns a high frequency rectified square wave into flat DC. Linear regulators have no analog to this.
            LDOs want certain amounts of capacitance and ESR on their output. National has a pretty good writeup on the topic and how linear regs work in general if you're interested.
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              No.
              The charge and discharge you are thinking about is DC.
              ESR -only- affects AC.
              Mann-Made Global Warming.
              - Dr Seuss
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                This might help.
                - Dr Seuss
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Z² = ESR² + (XL - XC)²
                  There is a point where XL = XC.
                  At that point Z = ESR.
                  It's roughly around 100kHz for most caps we talk about here.
                  - Dr Seuss
                  • Trinite
                    • 143
                    Originally posted by PCBONEZ
                    No.
                    Don't most applications of electrolytic capacitors involve DC? For example, output filter caps deal with already rectified current, so it is going to be DC. Since ripple is simply variation in the voltage and not a cycling between positive and negative, how would ESR play a role in DC filtering then?
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      It removes the Ripple.
                      The Ripple is shunted to ground through the cap leaving the DC 'clean'.
                      Remember, AC goes THROUGH a cap.
                      DC does not. It charges it.
                      The Ripple's point of reference [zero] is the DC voltage.
                      That's why it is said to be 'floating' on the DC voltage.
                      Since DC is it's reference it IS cycling between positive and negative.
                      - Dr Seuss
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Case 1.
                        Cap has +5vdc on it and 100mV Ripple on it.
                        - What does the cap do with the Ripple?
                        Case 2.
                        Cap has 0vdc on it and 100mV Ripple on it.
                        The cap's responce to Ripple doesn't change with the amount of DC.
                        That's why you disregard the DC when looking at the Ripple.
                        - Dr Seuss
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          You have to stop thinking like the AC and DC are mixed.
                          Caps don't treat them like they are mixed.
                          That's why they are useful as filters.
                          - Dr Seuss
                          • Trinite
                            • 143
                            Ah, that seems to make sense. I was thinking in terms of reference to ground, rather than DC the voltage present.
                            • MORETTIGIAN
                              Capacitor detached from PCB – RTX 2070 Super Founders Edition
                              by MORETTIGIAN
                              Title:
                              Description:
                              During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                              I did not notice it detaching, so I am unsure of its original location on the PCB.
                              Procedure performed:
                              - Removed backplate
                              - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                              - Reapplied thermal compound
                              - Reassembled card
                              Observed behavior after reassembly:
                              - GPU powers on and operates normally under...
                              09-18-2025, 12:14 PM
                            • chth96
                              What capacitor should I purchase for Power Supply of obsolete game consoles?
                              by chth96
                              hello.
                              I have Sega Saturn and 5 years ago, I recapped all of capacitor in the Power supply, Because At that time, It frequently freezed black screen after SEGA logo displayed.
                              It hardly ever freezed after I finished to recap all of caps in the power supply.
                              But Yesterday, It did not show any screen at all and its green power LED constantly blinked.
                              To my surprise I found that all of two NXH 10v 2200uf capacitors in the secondary area of Power supply have been bulged and It measured 57 mF and 75 mF capacitance.
                              It seems that quality...
                              10-01-2024, 08:14 AM
                              DVR camera recorder switching power supply capacitor failure really
                              by sam_sam_sam
                              These cheap non brand capacitors at it again
                              Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
                              Well at least I have the cameras back on line I to try the...
                              01-22-2022, 06:28 PM
                            • r2digital
                              klipsch kda-500 amplifier suitable power supply capacitor replacement ?
                              by r2digital
                              I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
                              04-18-2024, 03:50 PM
