Chieftec HPC-360-202 360W
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    We seem to be having a lot of reports of Antec fails. I always understood Antec and Chieftec to be the same company but that is in fact incorrect. Whilst Antec and Chieftec cases look the same they are apparently made by Chenming Mold Inc. Corp which also markets under it's own brand UNEEC http://www.uneec.com
    This PSU came in a Chieftec case which i have used as my main case for several years. You can see a pic if you click below. They are extremely heavy cases.
    The PSU model is HPC-360-202 360W and an internet search revealed it appears to be made by High Power http://www.highpowersupply.com
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Chieftec HPC-360-202 360W
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        the fan is SUPERRED made by Cheng Home Electronics. http://www.chenghome.com.tw/ it is not very powerful at all.
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              the caps are all either Teapo or Jenpo
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                680uf is quite poor
                • willawake
                  Super Modulator
                  • Nov 2003
                  • 8457
                  • Greece
                  • willawake
                    Super Modulator
                    • Nov 2003
                    • 8457
                    • Greece
                    little Teapos and Jenpos
                    • Rainbow
                      • Aug 2005
                      • 1372
                      The long pins on the small daughter board mounted vertically on the main PCB look scary to me - they're very close to the cover (when it's closed) and it don't see any insulation there. I've seen daughter boards like this but always with plastic insulation on the back.
                      • willawake
                        Super Modulator
                        • Nov 2003
                        • 8457
                        • Greece
                        i was thinking the same thing. a square of electrical tape on the case or better hot glue over that board would be fine. they used plastic insulation on the other side of the board where it is practically useless so i think someone messed up there.
                        • Rainbow
                          • Aug 2005
                          • 1372
                          Probably someone put in that plastic backwards...
                            Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
                            The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
                            Securing a good thermal interface between...
                            10-07-2024, 04:35 AM
                          • nick122
                            Chieftec (Delta) GPS-450AA-101 A repair and possible upgrade options?
                            by nick122
                            Hi everyone!
                            I’m trying to diagnose (and perhaps even upgrade) this Chieftec (Delta rebrand) power supply from an old rig
                            The computer just stopped turning on one day. No explosions, no magic smoke, it just died.
                            There is no 5vsb, and nothing happens when I try to jump start it, it’s completely dead…
                            I took it apart and nothing looks out of the ordinary. The fuse isn’t blown and the main cap gets charged (found out the hard way lol)
                            The caps are mostly ltec with a samxon primary, none of which are bulging
                            Any ideas what I should look...
                            01-05-2025, 04:31 PM
                          • sirpsychol
                            Antec Earthwatts EA-380 smd element type/value
                            by sirpsychol
                            While recaping Antec Earthwatts EA-380 I've broke one side of unknown smd element, it have no print, it's flatter and darker than smd capacitors on this board, shaped more like resistor but it's not resistor ofc. Unfortunetly the printed description was under it and element was glued to the board so I cant read/tell the letter before element number too. Have anyone any idea what it is? Maybe is there any diagram of this PSU?
                            09-03-2023, 07:58 PM
                          • ajdrenter
                            Picking caps for Antec SU-380
                            by ajdrenter
                            In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
                            https://www.badcaps.net/forum/showthread.php?t=14159
                            It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
                            05-13-2023, 10:40 AM
                          • dmill89
                            Chieftec Dragon LGA1366 Build
                            by dmill89
                            I recently got ahold of a bright green Chieftec/Chenming "Dragon" case (I've always liked these cases, especially in "oddball" colors) and decoded to throw together a period correct-ish build.
                            Components:
                            Motherboard: Gigabyte GA-X58A-UD3R:
                            CPU: Intel Xeon W3680
                            RAM: 24GB DDR3-1333
                            GPU: Nvidia GeForce GTX1060 (I know a GTX1060 is a bit too new, I was going to use a GTX780, but it was too long to fit with the lower HDD cage installed, and the GTX1060 provides similar performance)...
                            02-26-2024, 06:32 PM
