How does this switching PS work ?
  • michel74
    • Oct 2023
    • 8
    • Switzerland
    Yes ! How does this switching PS works ? :-)
    I understand (not in deep, of course) the switching PS principle; typically, I'd expect to get a VCC just to "feed up" the STR or the Switching regulator, but I cannot figure how this VCC is "created" (on a TV switching PSU, I often see some cascaded resistors, but here, I believe that one of the transformer input should make the permanent VCC, but I cannot figure where )
    Thanks for your help. I already wrote some explanation of what I was having and did some measurements here
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: How does this work ?
    IC901 gets its Vcc from T901-1 and -2. Could not find datasheet
    IC921 gets its Vcc from T903-2 and -3. https://html.alldatasheet.com/html-p.../1/MR4020.html
    PeteS in CA
    • michel74
      • Oct 2023
      • 8
      • Switzerland
      Thanks PeteS,
      I got these ones, :-)
      My question was more about how we get this permanent VCC? When the A/C plug is .. plugged, we should have a permanent VCC “somewhere”, no ?
      • petehall347
        • Jan 2015
        • 4432
        • United Kingdom
        will be at rectifier .
        • R_J
          • 9580
          There is likely a built in resistor or what is called a startup cell from the Drain pin that supplies initial vcc voltage to start the ic.
          • PeteS in CA
            • Aug 2005
            • 3581
            Re: How does this switching PS work ?
            Page 7 of the Shindengen regulator datasheet (which I linked)explains the derivation of Vcc during start-up. There is an internal current source the supplies current through the Vcc pin, charging the external filter capacitor. Once the Vcc voltage is high enough, the regulator starts to operate, the current source is disconnected from the Vcc lin, and Vcc is supplied by the bootstrap winding.
            I could not find a datasheet for the other regulator, but I expect it operates similarly.
            PeteS in CA
