12V 10A CCTV camera system power supply pulsating
  • CapLeaker
    replied
    Re: 12V 10A CCTV camera system power supply pulsating
    Originally posted by rddube
    Ok, cleaned the probes and deoxed them, but the lowest I get with very high quality probes is .5 ohms, there is no way to 0 it. Whereas the cheaper tester Tais TA118A is dead 0 ohms when connecting the 2 probes together. It cost +- 40$ compared to the Fluke 87 V which had cost me over 500$. Probably need calibration and cleaning, but they're asking over 300$ CAD to do this at Fluke, not worth it.
    If you get real good probes, you will get it down to 0.2ohm. Flukes usually do not go down to flat zero as it measures the resistance of the leads. She is fine and well within tolerance.
  • harp
    replied
    It is not neccesery to remove secondary diode again, unless (like I mentioned before) you feed 12Vdc to output and simultaniously power psu from mains 220Vac, due to specific testing purpose.
    So yes, just feed 12v and check again pin1&3 of TL431 and primary side of optocoupler, maybe to try reverse probe, or other dmm... if in off state is 3k reading accross pin3&4 of opto, then when interLED power on must be some lower reading, dont you think?
  • rddube
    replied
    Originally posted by harp
    Open the fluke and clean pcb rotary switch with contact cleaner, and its parts in plastic on button side.
    Optocoupler have npn inside, and when lights go on, resistance go rapidly down. Check this whats are going on, even it is not your primary problem. When you feed secondary with 12v, you must have about 2.5v on tl431 reference pin1.
    Ok, will try that for the Fluke.
    For the 2.5V, you want me to remove the output diode and test again injecting 12V in the output side?
  • harp
    replied
    Ok, so I guess my old Fluke needs calibration
    The optocoupler is maked EL 817 - this is the 3rd optocoupler, but I think they are all good
  • rddube
    replied
    Probably doesn’t need calibration, rather a good cleaning where the probes go in and a quality new set of probes. Sometimes you can kind of restore them a little by cleaning with 99% alcohol followed with some Deoxit.
  • CapLeaker
    replied
    Ok, so I guess my old Fluke needs calibration - I used another (cheaper) multimeter and R3 measures .1 ohm...when I put my probes together it measures 0.0 ohms. So R3 is good.
    The ground I use to make the measurements on the IC are the main caps ground which is on the primary side. When I put 0V for pin 1, it was just that that's what I recorded to later realize it's ground.
    The optocoupler is maked EL 817 - this is the 3rd optocoupler, but I think they are all good.
    Quite a mystery!
    Probably doesn't need calibration, rather a good cleaning where the probes go in and a quality new set of probes. Sometimes you can kind of restore them a little by cleaning with 99% alcohol followed with some Deoxit.
  • rddube
    replied
    rules that out then ..
    what is connected to pin 4 ?
    Pin 4 is connected to R9 a 28kohm resistor.
  • petehall347
    replied
    Pin 5 is not connected to anything so probably not used?
  • rddube
    replied
    does it have an ntc connected to pin 5 ? if so what value is written on it ?
    pin 5 needs to be over 1.05v or pwm is disabled
  • rddube
    replied
    Quite a mystery!
  • CapLeaker
    replied
    What do you read by just touching the two probes together?
  • petehall347
    replied
    Originally posted by lotas
    Yes, you correctly noticed that the current resistor shows R3 1.1 Ohm, but it should be 0.18 Ohm, this could be a problem.
    or meter error .
    replied
    just a thought.
    when you take these readings, are you getting the ground from the input for the input-side and from the output for the output side?
    because the 2 grounds arent linked.
  • lotas
    replied
    From pin6 to ground is power resistor, what value, I see brown gray silver gold, and you measure 1.1R?
  • harp
    replied
    If you disconnect psu from mains, and remove secondary output diode and then feed adjustable 10-14v to output terminals, so that tl431 circuit is working, you can monitor opto transistor resistance (primary side) and confirm that switch on at 12v point. Set on 12v with trimpot 1K.
    Ok, so did the above test - removed secondary output diode, injected 12V on the output and took measurements of optocoupler resistance primary side:
    No voltage applied (power off) - 3.191K ohms
    10V applied - 1.086Mohms
    12V applied - 1.086Mohms
    13.3V applied 1.088Mohms
    Strange, I was expect that resistance go down from initialy... What is optocoupler marked name?
    So it seem the problem is on primary side, or transformer.
    And I notice one more thing... where is ground, you noted like GND or 0V... if ground isnt 0.000v that means that somewhere on board is short witch pull up a ground awhile. Is ground pulsating last digit-two also?
  • petehall347
    replied
    replied
    pin7 is fed by a diode - can you check it.
  • rddube
    replied
    best i can think is drain power from main cap . mains power disconnected first of course .then measure resistances each pin reference pin 1 ground .
    Pin 1 - Gnd -
    Pin 2 - 0.656MΩ
    Pin 3 - 1.487MΩ
    Pin 4 - 28.09kΩ
    Pin 5 - .915MΩ
    Pin 6 - 1.1Ω
    Pin 7 - 1.2MΩ charging
    Pin 8 - 9.54kΩ
  • petehall347
    replied
  • rddube
    replied
    i take it the supply voltage is stable at the main cap ? think this mentioned so ..
    pin 6 you missed for some reason ..
    Sorry pin 6 I had written down but did not put it in the list for some reason:
    pin 6 - 0V
    by sam_sam_sam
    03-31-2024, 02:12 PM
    by sam_sam_sam
    07-01-2024, 06:34 AM
  • JimBanville
    Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
    by JimBanville
    The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
    Opened it up and discovered the power supply is making a faint clicking or ticking sound.
    I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
    I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
    09-13-2023, 07:21 AM
  • madan1
    555 based power supply getting too hot
    by madan1
    Good day.
    I have an AC/DC -> DC PWM (rectifier + 555 buck converter) power supply with MDF11n60, which is getting very hot.
    The input is AC from a transformer and the output powers a 24v dc fan. The power supply is used to regulate the speed of the fan.
    After several runs on the bench power supply I noticed that the mosfet is reaching 80+C*. The mosfet reads fine on component tester, the thermal paste is changed, the fan is cleaned and with freshly oiled bearings.
    When powered directly from the bench psu, the fan takes ~0.7A on 12V. The current consumption is similar...
    06-23-2025, 04:38 PM
