While recaping Antec Earthwatts EA-380 I've broke one side of unknown smd element, it have no print, it's flatter and darker than smd capacitors on this board, shaped more like resistor but it's not resistor ofc. Unfortunetly the printed description was under it and element was glued to the board so I cant read/tell the letter before element number too. Have anyone any idea what it is? Maybe is there any diagram of this PSU?
					Antec Earthwatts EA-380 smd element type/value
	Tags: None
Re: Antec Earthwatts EA-380 smd element type/value
Without knowing what I broke didn't try to power it on. Not sure if it safe for rest of PSU. At first I thought it was capacitor but after closer look I realized that never seen any like this, looks too flat.
EDIT: Excuse the pic quality. I've lifted it to show damaged side structure.
SMD caps come in various sizes in length, width and heights. To me it’s a small cap. Since it is on the secondary, put probably something like 25v or better with a smallish value like 0.1uF in there and call it good.Comment
You were quite accurate, I found same model in my little private scrapyard, faulty but after storm damage, soldered out that capacitor and measured it, it's 2uF. Thank You.Comment
			by flyskyThere is a motherboard Gigabyte H610M S2H V2 (DDR5), I can't find boardview
Help to identify the element, marking on the element - C31PH. It stands next to the USB 3.0 and it looks like it is ESD Protect chip. We need a datasheet to this element. Maybe someone has already identified such an element. Help please.
			by EasyGoing1I've got this circuit that I've been playing with on a breadboard. I'm not happy with it mainly because the MOSFET gets too hot and generally controlling the temp of the heating element with the Arduino has proven to be a little more cumbersome than I would like.
What I would like to know, is what is the best way to set up a circuit like this? The heating element is just a PCB and its going to be mounted under a 3D-printed enclosure that a lizard will use to warm his belly.
This is the general setup that I have now.
This is what the... -
			by sam_sam_samI was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap... -
			by wwbielskoHi,
one sms element is missing at touchpad pcb in Macbook A1707
Could anyone identify it ? Smd element is pointed on pictures
thanks... -
			by fraser34Hi,
Can anybody, please, help to identify this burnt element on ZOTAC GeForce RTX 2060 6GB 192BIT GDDR6?
It says something like "6UDN..." on it.
Thanks... - Loading...
