Huntkey model: Hkf1502-3b
  • EonFlask
    • Jan 2020
    • 8
    • Phillipines
    I would like to share with you the good voltage testing of SMPS HK1502-3B for Lenovo All In one computer.
    this is resonance Half bridge.
    The 198VDC comes from the resonance IC supplying the Transformer for the 12VDC.
    2. Check first the Big Filter capacitor using voltage testing (DC) with around 395 -400VDC if sometimes you see 350V check the Big Filter capacitor first but for me I all I encountered the IC for the resonance IC has issue if 198VDC is show this means that resonance IC is working properly.
    3. Other issue mostly the POWER IC: TNY278PN and the defective starup resistor replace it with the value of 2.2Ohms.
    You will see my attachments all voltages comes from the good working SMPS.
  • aripware
    • Jun 2021
    • 7
    • indonesia
    Re: Huntkey model: Hkf1502-3b
    thanks for share
    • canali
      • Oct 2014
      • 192
      • turkey
      thanks for share
      • spleenharvester
        Weirdly specific reboots on a TrigKey S5 that seem to be power supply related.
        by spleenharvester
        I have two of these mini PCs: TrigKey S5 with Ryzen 5700U, 32GB RAM, 1TB NVMe SSD, Win11 Pro. They work very well for most uses. They are powered by a HuntKey 19V 4.74A brick with a standard DC5525 tip, which feels decently heavy.
        When the brick is connected to the system through a 1 meter DC female-male extension cord (18AWG so decently thick), the system will black screen and reboot when multiple objects are sliced simultaneously in PrusaSlicer. One object is OK. Literally any other activity on the PC is OK. It is just this one specific thing that causes a reboot. I tried running...
        09-15-2025, 08:43 AM
      • cheese007
        Input Filter Filling: How to Choose Components?
        by cheese007
        Recently acquired one of those silly Logisys acrylic power supplies and lucked into getting one of the "better" ones (most of an input filter, bridge rectifier instead of 4 diode treatment, OK-sized heatsinks, etc.) and wanted to fill out what I can on the board + get some decent caps on there (especially the primary side since I highly doubt the ones in there are actually 1000uf). My questions are:
        1. How do I know what components to install re: the input filter? It seem to be missing an X cap, a resistor, and a Y cap.
        2. Where can I find a good heatsink for the bridge...
        12-06-2023, 09:59 AM
      • PennyLane
        Trying to locate a capacitor for a Skytec Crossover filter
        by PennyLane
        Hi
        I'm trying to locate what i believe to be Radial Electrolytic Capacitors 100v 82uf Non-polar for a Skytec Crossover filter.
        02-19-2025, 06:47 AM
      • J_T
        Operating frequency for motherboard common mode inductor/filter
        by J_T
        I have a question - I have replaced the PSU on my own iMac Pro. However, when removing the motherboard I knocked of a 120 OHM 30% 0.3A small surface mount common mode inductor/filter (~0602 size) in the ethernet circuit near the female RJ45 port.
        The closest match I can find on Mouser is 120 OHM common mode inductor at 100MHz - my question is this frequency correct for a motherboard? The schematic for the motherboard only provides '120 OHM 30% 0.3A' and the TDK part number does not return anything in google.
        Sorry, I am not experienced hence a basic question.
        01-04-2025, 05:54 AM
      • acedogblast
        Power supply for main amp blows fuses after replacing filter caps.
        by acedogblast
        Hello I have a Marantz sr5012 that I have been repairing. After I have replaced the 2 main filter caps the 2 fuses for the power amplifier blows. The original capacitors are ELNA LAO 10,000uF 71V and the replacements are Nichicon LKS 10,000uF 80V.
        I assume a short circuit connection has occurred so I set my multimeter to measure ohms across the 2 fuse connections and both read 55 Kilo-ohms so I assume that is ok.
        I am certain that I do not have any bridges on my soldering and after probing around I do find a temporary 0 ohm reading when probing across the positive and negative...
        02-27-2023, 05:11 PM
