Nvr supply Delta DPS-300AB-81B circuit
  • alltvrepairs
    • Jan 2014
    • 219
    • Malta
    Hi
    Am trying to repair this supply. Do we have a circuit pls?
    Goynd Mosfet blown. Replaced, check for other shorts 9rvopen bias resistors but blew again at switch on.
    Outputs: +12v , -53v.
    Regards
    Darren
  • alltvrepairs
    • Jan 2014
    • 219
    • Malta
    Re: Nvr supply Delta DPS-300AB-81B circuit
    The problem is in the PFC curcuit blowing Mosfet.
    Uses IC CM6800 pfc contrller. Supply pins +16v healthy.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8179
      If the mosfet is shorted to the gate, chances are that the gate drive blew up too. So yes, that includes the pwm and anything between it and the gate of the mosfet.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
        03-31-2024, 02:12 PM
        MSI Delta DELTA 15 A5EFK-008 Notebook 15 Specification for Upgrade or Repair
        This specification for the MSI Delta DELTA 15 A5EFK-008 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the DELTA 15 A5EFK-008 boardview and DELTA 15 A5EFK-008 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
        09-07-2024, 03:40 AM
      • Jane
        How do you test MOSFET in laptops ?
        by Jane
        I tried to use this method:
        Testing an N-channel MOSFET:
        Step 1: Discharge the Gate (turn off the MOSFET)
        Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
        Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
        Step 2: Charge the Gate (turn on the MOSFET)
        Now, place the red probe on the Gate (G) and the black probe on the
        09-27-2024, 03:31 AM
      • sententia
        Philips 32PFL7403D/12 - Shorted mosfet -Delta DPS-182C Ppower supply
        by sententia
        Hello everyone!
        I am trying to repair this power supply and i seem to be kind of stuck...
        Mosfet Q603 was shorted, which also took out R634 ....
        The small main cap C910 (33uf) had leaked and was off...
        I have replaced both mosfets, the capacitor and the resistor and now have standby power but as soon as the relay clicks to switch on the TV i get 6 blink error led.... according to service manual its the 5V 12V supply error....
        I cannot find any other damaged parts, does anyone have any suggestions or can point to a direction...
        05-31-2021, 01:17 PM
