Another Antec PS PP-303X 300W
  • DJ_MIX
    • May 2005
    • 118
    Yes another antec PS with Fuhjyyu CAPS..
    mine was weird... I had 2 boards act weird...
    1st one the atx power connector had 1 pin with a burn mark.
    2nd board one day my pc rebooted and it would not startup any more...
    so I tested the cpu 1st it worked, then I placed it back in the same board nothing..
    so I tried another Power supply bingo it works...
    BTW the Antec power supply still works... going to replace the caps latter..
    Wanna wait a few days to discharge the caps...
    here's some pics...
  • Rainbow
    • Aug 2005
    • 1375
    Re: Another Antec PS PP-303X 300W
    The big caps will discharge in a couple of seconds on most ATX PSUs. First check the voltage between the metal case and the heatsinks - there should be none. Then remove the PCB (carefully to not touch the bottom side) and measure voltage across the big caps - if there's none, it's safe.
    • DJ_MIX
      • May 2005
      • 118
      Rainbow thanks for the advice on using a voltmeter..
      that make me more comfortable against getting a shock..
      anyway I recap all the caps except the 2 big ones...
      PS is running as I type...
      • Loki_Fido
        (Weird) BIOS info for HP Pavilion Aero 13-be1021AU
        by Loki_Fido
        Hi folks,
        This HP Pavilion Aero 13-be1021AU came to me for a repair. And it seems to have a weird BIOS chip. (Pic attached)
        I asked my CH341A to read it and doesn't even know what to do with this. We are both very confused.
        BIOS - XMC 25RU128CH10 (1.8v)
        What the heck is this? I looked all over the MB. This is the only bios.
        When I asked the NeoProgrammer to detect it, it just pops up an empty screen, and asked me to enter the bios number. And when I did, it doesn't do anything. NeoProgrammer showed me just this SPI ID: 204418. Don't know what...
        03-20-2025, 01:57 AM
        APC BR1000G battery backup has a weird issue sometimes a bad battery icon and making a weird sound for about 30 seconds
        This started a few days ago and does this about every 8 hours
        After it does this it goes back to normal no bad battery icon and no weird sounds and it goes to battery backup mode so I am not sure what is going on with this battery backup
        The battery backup is about 3 or 4 years old
        Dose anyone have any idea on how to troubleshoot this issue I have never had a battery backup do this kind-a thing before so I am not sure exactly how to troubleshoot it and where to start
        06-02-2024, 02:30 AM
      • ugamazing
        820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
        by ugamazing
        So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
        1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
        2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
        04-10-2024, 08:06 AM
      • estabilito
        Acer Nitro AN515-55 weird behaviour on startup
        by estabilito
        Hi, I've just repaired acer nitro an515-55 with specs:
        i7-10750h, rtx2060.
        Laptop had damaged cpu and after replacement came back to life but i have weird problem with this machine.
        After night or 2-3hours on first startup laptop shows acer logo, windows circle for second and then screen goes blank - machin stays on but i need to turn it off by holding power, on next startup laptop working just fine.
        i've tried different bios, different vbios and same behaviour - clean windows install too.
        Do you have any idea?
        08-13-2025, 02:52 PM
      • lukkihapsi
        Asus Vivobook X515JA Weird Boot Issue
        by lukkihapsi
        Asus Vivobook X515JA Laptop
        Issue :
        Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
        Tried :
        Cleaned inside for dust, applied fresh thermal paste. No Change!
        Removed keyboard, Trackpad, fingerprint sensor. No Change!
        Removed Internal SSD. No Change!
        Updated BIOS to latest version. No Change!
        Removed battery and pressing power button for 1 minute. No Change!
        Weird Part :
        Upon turning laptop ON, screen lights up - stays black,
        I...
        07-07-2025, 12:07 PM
