ID'ing a device
  • JEWilson
    • Sep 2007
    • 369
    • Scotland, United Kingdom
    ID'ing a device
    Cannot, for the life of me find a datasheet on a device I would like to ID
    Any help appreciated!
    Three pin device is marked as A 506 D13009K
    Is this a transistor, MOSFET or what?
    Cheers
  • everell
    • Jan 2009
    • 1514
    Re: ID'ing a device
    Most likely a MOSFET in the 13009 family. Several manufacturers make the 13009 FET. So the other numbers and letters would be for a specific manufacturer.
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
    • jetadm123
      • 2169
      Re: ID'ing a device
      Possibly a 400V 12A NPN transistor. Made by several companies. The one I attached is made by Fairchild.
      • Jane
        How do you test MOSFET in laptops ?
        by Jane
        I tried to use this method:
        Testing an N-channel MOSFET:
        Step 1: Discharge the Gate (turn off the MOSFET)
        Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
        Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
        Step 2: Charge the Gate (turn on the MOSFET)
        Now, place the red probe on the Gate (G) and the black probe on the
        09-27-2024, 03:31 AM
      • littlejohn
        mosfet or transistor ?
        by littlejohn
        I'm working on a LED circuit board and am testing a 8C 1A component, it has a wide ground tab on one side and 3 tabs on the other and the center tab is grounded also. the circuit board has it as a V2 component ,so is this a mosfet or transistor ?
        08-03-2025, 10:32 AM
      • Nooy
        VGA MOSfet permanently shorted and loss of MOSfet pad
        by Nooy
        Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
        I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
        02-14-2024, 02:26 AM
      • Yolofolkss
        Asus X99-pro/usb 3.1 Usb overcurrent device reoccurring issue
        by Yolofolkss
        Hi this is a really odd case.
        I have removed all of the esd ic for USB 3.0 and 2.0
        I measured all of the data lines and 5v usb voltage lines there are no shorts
        all of the USB ports have no damage
        Clearing the bios using the jumper wont help.
        it is still showing USB overcurrent device
        the only temporary fix I've tried and worked so far is flashing the bios
        and the error is gone
        but when you start the motherboard with a USB device still attached
        the USB over current device error is back. the bios needs to be externally flashed...
        01-09-2023, 04:21 AM
      • redbaron1007
        Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
        by redbaron1007
        I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
        Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
        09-09-2025, 11:10 AM
