Hedwig-6050a2993001-mb-a03
  • pyrojack2001
    • Mar 2018
    • 17
    • philippines
    Hi guys can you please help me, I needed a schematic diagram and board viewer for HEDWIG-6050A2993001-MB-A03. This for HP 14S CF2041TU. Thanks in advance
    pyrojack2001
  • pyrojack2001
    • Mar 2018
    • 17
    • philippines
    Re: HEDWIG-6050A2993001-MB-A03 HP 14S CF2041TU
    pyrojack2001
    • noipi
      • Aug 2017
      • 75
      • Singapore
      help schematic HP 14S CF2041TU
      anyone has schematic of
      • manuel.it.solution
        • May 2020
        • 30
        • Ghana
        Anyone with schematic for 6050A2993001-MB-A03
        Please anyone with the schematic diagram for
        Mobo number
        6050A2993001-MB-A03
        • pyrojack2001
          • Mar 2018
          • 17
          • philippines
          Re: Anyone with schematic for 6050A2993001-MB-A03
          Still waiting for reply to help me with schematic and board viewer
          • mon2
            • 14476
            Re: Hedwig-6050a2993001-mb-a03
            What is the fault? Could not locate the requested files in my database.
            • pyrojack2001
              • Mar 2018
              • 17
              • philippines
              Hi mon2 it when you power. there is no display and the cap locks blinks 4 times. Hope you can help me. Thanks in advance.
              • mon2
                • 14476
                From the hp website:
                The Diagnostic LED blinks red 4 times (once per second), then a 2-second pause follows, and then it beeps 4 times:
                This indicates power failure.
                Since we cannot locate a schematic, you will have to post pics of the board. You should start a fresh thread in the laptop forum regarding this laptop.
                Then, review where the power adapter enters the logic board. In this area will be 2*DCin mosfets and the charger IC. The charger IC will be a black square device. We need to know the topside markings of the IC.
                Often, HP will use charger ICs with 'BQ' markings from Texas Instruments.
                Post pics.
                • pyrojack2001
                  • Mar 2018
                  • 17
                  • philippines
                  Thanks Mon2 will update if I ever find the defective component.
                  • erickj007
                    • Oct 2021
                    • 6
                    • Philippines
                    I'm also looking for schematic or board view of this board.. encountered a problem 5 long 3 shorts, i already flash bios via keyboard PC run for several days and return to 5 blinks and 3 shorts. I tried replacing the memory, check and soldered ram slot pins - no luck, I also clear ME and flash bios and using CH431a programmer still no luck.
                    TIA
                    • myohtetnaing
                      • Jan 2024
                      • Myanmar
                      Help me this MB Schematic HEDWIG-6050A2993001-MB-A03
                      • Chapita
                        Dell latitude 5289 schematic diagram a d board view needed
                        by Chapita
                        Hi friends, anyone to assist with the schematic diagram and boardview for dell latitude 5289 with board number CAZ LA-E111P....
                        09-15-2024, 03:18 AM
                      • businessmind1988
                        HP CQ61 SCEHMATIC DIAGRAM NEEDED
                        by businessmind1988
                        please i need schematic for HP CQ61
                        mobo number DA00P8MB6D1 REV
                        09-28-2024, 07:59 AM
                      • hs5424
                        Dynacord powermate 1600 block diagram.
                        by hs5424
                        Hi All,
                        I obtained a schematic diagram for the above mixer but I am wondering if a block diagram exists as I am trying to fix a problem in the protection circuit which I find a little confusing using a circuit diagram only. In the good old days the workshop manuals always had a block diagram with a circuit discription. Very useful for fault finding.
                        The protection light is perminently on. The right sode has a -80DC on the feed to the speaker, hence the protection led on. I have removed all the O/P transistors which checked out OK. I tested all other transistors in circuit which seem...
                        07-31-2025, 01:35 PM
                      • Techmanx
                        Schematic Diagram Needed
                        by Techmanx
                        I have a Yorkville Audiopro 208 Performance Mixer (full name on device - 8 channels, non-powered). Not only can I not locate schematics for this, I cannot find a user manual, a picture or any reference whatsoever to this mixer on the entire internet and I have looked really hard. Not a single mention anywhere. It's like it never existed, yet it does. I have been sourcing schematics for decades but have never run into to this before. In this day and age, how is this even possible?
                        It appears to have the same mixer stage as the Audiopro model 508 but this unit has a built in power...
                        07-05-2023, 01:41 PM
                      • scott budworth
                        Lenovo x13 Yoga Gen 2 Persistance
                        by scott budworth
                        Hello, Guys.
                        i have been reading some forum messages here reguarding absolute persistance.
                        I have a laptop i bought a while back and just noticed it has been enabled & activated on this machine. I have contacted absolute persistance and they have confirmed it's not reported stolen (proof will be attached)
                        To get this removed the process can take upto several months and i have seen here you guys can modify the bios file?
                        im quite green when it comes to this kind of thing and hope you guys can help me.
                        on some posts i have read...
                        09-02-2024, 12:03 PM
