ASUS PRO bu201la REV 2.0
  • kokono
    • Jun 2018
    • 203
    need schematic
  • mon2
    • Dec 2019
    • 14115
    Re: ASUS PRO bu201la REV 2.0
    Can only find the boardview file.
    • kokono
      • Jun 2018
      • 203
      Very thx
      • Sebastian Codrean
        BIOS file for ASUS F542UN laptop
        by Sebastian Codrean
        Hello to all of you! I need help with a BIOS file.
        The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
        So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
        02-20-2025, 10:25 AM
      • ShadowAi
        ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
        by ShadowAi
        Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
        Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
        After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
        03-15-2024, 10:46 AM
      • Dr Techno
        Motherboard Schematic and BoardView file for a AORUS 15P XC please
        by Dr Techno
        Hi Guys,
        I need a motherboard schematic for file for a AORUS 15P XC please. The EXACT motherboard is ga-rx5lxc rev2.0. It currently has a black screen issue and doesn't display to external display but boots into windows and can also display externally when running ubuntu. If anyone has a motherboard schematic file and boardview for this laptop it would be greatly appreciated. Thanks in advance!​
        05-01-2025, 01:45 PM
      • rickjansen01
        Asus FA707 corrupt Bios File
        by rickjansen01
        Hello Guy's
        Can somebody help me whit this problem
        Asus FA707 bios file is corrupt
        sn T3NRCXCZR00Y117
        original file uploaded
        Regards chris...
        04-20-2025, 07:12 AM
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
