Asus k401uq bv
  • computeka
    • Apr 2021
    • 31
    • colombia
    Asus k401uq bv
    Pls need Boardiew or schematic for ASUS K401UQ
    It does not turn on and there is 1 integrated part missing which I do not know its part number.
  • krimii
    • May 2023
    • colombia
    Re: Asus k401uq bv
    Hi! Did you get the boardview? i also need it
    • pooya_pm
      • Jan 2021
      • 254
      • iraq
      Re: Asus k401uq bv
      Board number?
      • Laboratorio JG
        • Apr 2025
        • 20
        • Colombia
        Originally posted by krimii
        Re: Asus k401uq bv
        Here!
        • Chewy6288
          Asus FA506QE missing MOSFET
          by Chewy6288
          I recently bought this laptop to try to fix up because it was so cheap. It has no power so I figured it was a MOSFET or cap issue so I started with taking it apart, but when I had it apart I noticed one of the MOSFETs was missing. I'm new to this so I don't know where or how to look up what to replace it with. I do have the boardview for it so I somewhat know what was there which I attached ,and the missing piece is PQ303....
          Yesterday, 07:24 AM
        • khabib
          ASUS STRIX G531GT MISSING PM_SLP_SUS#
          by khabib
          Hello guys i have ASUS laptop that power on but can't switch ons , i trying using power sequence and last missing PM_SLP_SUS# .
          here what i measure already:
          EC_RST# 3.3V
          SRTCRST# 3v
          +3VA_RTC 3V
          RTCRST# 3V
          ME_SusPwrDnAck 0V
          AC_PRESENT 3.3 V
          AC_IN_OC# 0V
          PS_ON 3,3V
          +3VA_DSW 3.3V
          DPWROK_EC /R 3.2V
          PM_BATLOW# 3.3V
          SM_INTRUDER# 2.8V
          PM_SLP_SUS# -----> MISSING VOLTAGE ( but sometime this voltage is present )
          THat is can confirm PCH relate issue...
          05-28-2024, 01:30 AM
        • gurj1979
          Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
          by gurj1979
          Hey guys.
          Need help with this one.
          Fan not spinning due to missing PWN Fan signal.
          Also 5 seconds from powering up it freezes, unless in BIOS.
          But as soon as Windows starts to load, it will freeze.
          CPU is COLD / Room temp when it freezes.
          I've replaced the CPU, same problem.
          Replaced SIO/KBC IT8987e and reprogrammed - same problem.
          Replaced fan - same problem.
          Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
          Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
          08-19-2024, 05:22 PM
        • madushanka 1234
          MISSING PART NEED TO FIND ...HELP ms-16r41 rev 1
          by madushanka 1234
          ms-16r41 rev 1
          PU7
          ANYONE HELP ME TO FIND THIS COMPONNET...(​​​​​​​PU7)
          I MISSING THIS PART RECENTLY..
          I NEED TO FIND IC MODEL..AND SIMILER PART..
          PHOTOS ATTACHED
          THANKS...
          02-11-2025, 09:09 AM
        • ShadowAi
          ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
          by ShadowAi
          Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
          Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
          After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
          03-15-2024, 10:46 AM
