ASUS GL504-GS Schematic HELP!!
  • Samuu12
    • Mar 2022
    • 5
    • España
    Hello! I've been looking for the schematic and the boardview of the GL504GS laptop or similar to it (GL504XX) for a while without finding the answer, it would be a great help if someone had it and could share it, thanks!
    PD: Sorry if my english is not perfect.
  • mon2
    • 13994
    Re: ASUS GL504-GS Schematic HELP!!
    I have sent you a PM. Maybe you can start a fresh thread in the repair side of this forum.
    What is the issue with the laptop ? Asus is rare to have schematics.
    I do see the BV from my paid subscription but either way, maybe you will not need the schematics for your repair.
    • newdes
      • Aug 2018
      • 34
      • MX
      I share the schematic, if someone has the boardview I will appreciate it.
      "Knowledge is to share"
      • tomodachi
        tomodachi commented
        Editing a comment
        Thanks a lot !
    • Samuu12
      • Mar 2022
      • 5
      • España
      My problem is that the previous owner overclocked the memories, without being aware of it, to which they were damaged and detects 6GB of the 8GB that it originally came with, this has resulted in my GPU clock being 134/ 138 Mhz, without the possibility of handling this, with low voltages, the gpu fan shot to 100 without being able to change anything, I suspect the controller ic that manages gpu voltages and that the overclocking of the memories has damaged other components, since it works fine , but I think that it has only damaged the GPU voltage ic or it has simply devalued the resistors that it has around it, thus giving faults like the one I have for low voltage that, if I remember correctly, were about 0.655 V.
      • ShadowAi
        ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
        by ShadowAi
        Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
        Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
        After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
        03-15-2024, 10:46 AM
      • newmemberguys
        Request: Schematic and Boardview for ASUS Zenbook S16 (UM5606WA) – 60NB13M0-MB5200
        by newmemberguys
        I'm looking for the schematic and boardview files for an ASUS Zenbook S16, model UM5606WA (2024).
        The reason I’m asking is that I recently caused some physical damage while trying to clip the BIOS chip with a CH341A programmer and SOIC8 clip. Specifically, I knocked off some components (possibly 6, though I’m not 100% certain as I don’t have much experience with this) around the bios chip as you can see in the photos attached. I was able to recover 3 of them which are now taped on the battery.
        To help with identification, here is the full...
        07-13-2025, 10:27 AM
      • whatamidoing
        Boardview/schematic for an ASUS E3-PRO V5
        by whatamidoing
        i'm looking for a schematic/boardview for an ASUS E3-PRO V5 (NOT E3 PRO GAMING, has a different layout).
        I'm trying to find out where i can find SKTOCC# other than from the socket in order to ground it for a Coffee Lake mod. It must be somewhere near/around the SIO but I haven't found a datasheet for the NCT5539D this board has.
        I've also found the schematic for the similarly named E3 PRO GAMING V5 but it has a different SIO so it's not of much help. And I don't trust myself to hold still a multimeter probe on top of a LGA socket pin to find where it comes out the...
        01-18-2025, 09:17 AM
      • mysnoopy
        Asus FX516PC R6.0 schematic
        by mysnoopy
        Hello
        I need schematic for this model ASUS FX516PC R6.0
        Thanks.
        12-27-2024, 03:41 PM
      • Kirve
        I need schematic and diagram for Asus X556U Rev2.0 mb
        by Kirve
        "Hello friends. My Asus X556U laptop is not charging, not turning on, etc. I wanted to repair the motherboard, partly for learning purposes. One of the capacitors is giving a 24V output, and one of the MOSFET pins is also giving a 24V output, and honestly, this surprises me. I think I need to replace the capacitor, but I don’t know the capacitance value. I tried searching for a motherboard schematic but couldn’t find anything. Can you help me find the schematic or diagram?"
        12-18-2024, 11:09 AM
