nm-b081 schematic
  • naseee
    • Nov 2016
    • 99
    • india
    nm-b081 schematic
    here boardview and schematic
  • n0by1
    • Apr 2017
    • 28
    • Россия
    Re: nm-b081 schematic
    Thank You! =)
    • shaon_kof
      • Feb 2014
      • 40
      • Bangladesh
      thanks
      • echow2001
        • Dec 2016
        • 40
        JTAG pinout if anyone needs. from schematic and boardview but laid out in one picture to put jumper wire easily. change jtag rst pull down to pull up to make jtag rst signal high
        • echow2001
          • Dec 2016
          • 40
          confirmed working last night move pull down resistor to pull up the rst line connect jtag programmer to those testpad. can successfully r/w the EC controller.
          • casaba
            • Apr 2014
            • 25
            • morokko
            Thank You
            • chandrakant
              • Nov 2017
              • 39
              • india
              Thank u
              • ari effendi
                • Jan 2019
                • 8
                • Indonesia
                Thank u
                • dqtech
                  Badcaps
                  • Jul 2018
                  • 630
                  • N/A
                  thanks
                  • SYR-ALEX
                    • May 2020
                    • 6
                    • WORLD
                    Спасибо
                    • SYR-ALEX
                      • May 2020
                      • 6
                      • WORLD
                      thanks
                      • Swell61
                        Gigabyte X570 Aorus Pro v1.0 boardview and schematic request
                        by Swell61
                        Hi
                        Does anyone have the boardview and schematic for a Gigabyte X570 Aorus Pro rev 1.0 please? I see there is a boardview for the WiFi version of this board on here but no schematic.
                        10-25-2023, 09:07 AM
                      • AstutePauciloquent
                        Seeking GA-M57SLI-S4 Schematic And Boardview
                        by AstutePauciloquent
                        Hi everyone, can anyone help me to find the Gigabye GA-M57SLI-S4 motherboard Schematic And Boardview. I am attempting to diagnose an ALC883 Audio codec, I have replaced the Audio IC with a new one, however the problem was not solved. I believe that if i am able to get hold of the Schematic And Boardview it will shed some light on BITCLK 24Mhz, and SYNC 48kHz clock that are both missing from the Audio IC, after powering on. I think it might have something to do with the clock IC.
                        Thank you in advance for your help.
                        10-15-2023, 11:37 PM
                      • Pier
                        ASUS MAXIMUS VIII IMPACT Boardview, Schematic & Repair Guide
                        by Pier
                        As the title states i am looking for a schematic and boardview for the ASUS MAXIMUS VIII IMPACT motherboard.
                        I know that the boardview exists (ASUS MAXIMUS VIII IMPACT REV1.01.fz) but cannot find it free of charge, the schematic however might not be leaked.
                        For anyone interested, the repair guide is attached to this post.
                        Thanks....
                        09-23-2023, 07:21 AM
                      • mozzwald
                        MSI GF63 9SCX MS-16R4 Schematic Boardview Request
                        by mozzwald
                        I am looking for schematic and boardview for the MSI GF63 9SCX MS-16R4 laptop.
                        Was dropped and screen broke but works with external video. Replacement screen and cable does not work. I found schematic/boardview for the 16R3 which is similar but it has a 40pin eDP connector and the 16R4 has 30pin. Want to test if the enable line for backlight is working or not.
                        05-22-2023, 04:15 PM
                      • motorptmotor
                        Schematic and boardview np730u3e Samsung
                        by motorptmotor
                        I need the Schematic and boardview np730u3e Samsung
                        This notebook has the following symptom:
                        when it is connected to the charger the Screen has an image with 100% brightness and as soon as I disconnect the charger from the notebook the image is at 50% and blinking with interference. I need the electrical schematic and boardview to make the diagnosis.
                        if anyone has an idea what it could be thanks
                        Board model: miranda13-e
                        Board ref. ba41-02235a...
                        05-11-2023, 02:06 PM
