Nm-c821
  • dspok
    • Jan 2014
    • 553
    • Nepal
    Nm-c821
    Please help me to get schematic or boardview for said model. Or any similar one. thank you in advance.
  • Argento7
    • Jan 2010
    • 27
    Re: Nm-c821
    Here friend.
    • vidrio jalisco
      • May 2016
      • 12
      • mexico
      Re: Nm-c821
      thanks
      • Kambi13
        • Aug 2022
        • 134
        • Portugal
        Lenovo IdeaPad 3-15ADA05 - LCFC NM-C821 Schematic
        Hi all, does anyone have the Schematic + Boardview for Lenovo IdeaPad 3-15ADA05 - LCFC NM-C821
        Best Regards
          • 21692
          Re: Lenovo IdeaPad 3-15ADA05 - LCFC NM-C821 Schematic
          Search the forum
          • kofe
            • Sep 2013
            • 32
            • Estonia
            Re: Nm-c821
            Thank You
            • gustarom
              • May 2013
              • 44
              • indonesia
              Originally posted by Argento7
              Re: Nm-c821
              Here friend.
              thanks alot broo
              • orresta
                • Nov 2013
                • 11
                • Argentina
                Thanks!!!
                • thebest
                  • Feb 2018
                  • usa
                  THANK YOU VERY MUCH
                  • sanalelevenstar
                    Yamaha RX-V485 receiver. After encountering a "version error"
                    by sanalelevenstar
                    I'm having trouble with my Yamaha RX-V485 receiver. After encountering a "version error", the USB, Bluetooth, and network functions have stopped working, making it impossible to perform a firmware update through normal methods.
                    After doing some research on forums, I found that earlier Yamaha models with similar issues (like the internal error message) could be fixed by shorting or soldering specific pads—such as R896—and then powering on the unit to enter a service/boot mode that displays the model info and allows recovery.
                    I managed to find the service...
                    09-10-2025, 01:54 AM
                  • NotEnough
                    Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
                    by NotEnough
                    I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
                    What I've Tried So Far:
                    • Reseated the cables.
                    • Reinstalled AWCC and AlienFX services.
                    • Attempted BIOS downgrade but no improvement.
                    • Inspected ribbon cables for damage.
                    • Explored the possibility of BIOS or
                    10-19-2024, 01:34 AM
                  • double_DD
                    Philips curling iron - is this a common AC cable?
                    by double_DD
                    Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                    As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                    Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                    08-18-2025, 10:04 AM
                  • SoulFreeze
                    looking for schematics for Lenovo Slim Pro 7 14ARP8 - Type 83AX, or similar
                    by SoulFreeze
                    I am trying to fix audio issues on a lenovo slim 7 pro im trying to repair, Has some issues with audio (sound only from bottom speakers, no sound from headphone (static) or palmrest speakers)and am looking for a schematic to troubleshoot, I suspect its something to do with the realtek ALC3306 chip, or unclean power to it.So a schematic would be useful, or any schematic utilizing the ALC3066 in a similar configuration, (2bass, 2 treble channels)
                    06-21-2025, 09:39 AM
                  • dota1990
                    unlock advance settings 100-14lbd
                    by dota1990
                    hi i want to unlock my advance setting on my 100-14lbd laptop hope you can help me...
                    03-20-2025, 11:24 PM
