nm-c711 schematic & boardview
  • nandraina free
    • Jan 2025
    • 6
    • Madagascar
    Thank you very much,friends
    • muhamad toha
      • Jun 2022
      • majalengka
      Originally posted by naseee
      nm-c711
      thanks
      • Betsdesanta
        • Nov 2020
        • 5
        • Mexico
        Thanks a lot
        • m1ch43lzm
          • Mar 2019
          • 1048
          • Peru
          Hi, can anyone reupload the schematics+board view from the first post? NM-C711
          • rockinho
            • Mar 2014
            • 13
            • Argentina
            do you need bro ?
            • m1ch43lzm
              • Mar 2019
              • 1048
              • Peru
              #26
              Originally posted by rockinho
              do you need bro ?
              Attachments on first post are working now, it was a forum/server issue at the time
              • Ernesto Freire
                • Apr 2023
                • 7
                • Brasil
                #27
                thanks
                • ismailakyoltr
                  • Mar 2015
                  • 109
                  • TURKEY
                  #28
                  nm-c711
                  Thank you
                  • Sergio Kub
                    • Jul 2018
                    • 178
                    • Brasil
                    #29
                    thank u !
                    • xquang77
                      • Apr 2016
                      • 10
                      • VN
                      #30
                      Thank You !
                      • mard312
                        Legion Go 8APU1 boardview or schematic
                        by mard312
                        I’m working on repairing a Lenovo Legion Go that suffered liquid damage. Unfortunately, one of the ICs on the motherboard burned out, and I haven’t been able to find any boardview or schematic for this model anywhere.
                        Does anyone happen to know what this particular chip is, or have access to the schematic/boardview for this motherboard? Any help or reference would be greatly appreciated.
                        11-12-2025, 01:01 PM
                      • AustinCER
                        In Search of Schematic/Boardview for Lenovo Ideapad Flex 5 14ALC7
                        by AustinCER
                        I am in search of a schematic or boardview for Lenovo Ideapad Flex 5 14ALC7.
                        No power and no charging LED with AC Adapter connected. AC Adapter is functioning at 19V, and also tried another Lenovo AC Adapter -- no charging LED still.
                        There is an active 19V from the USB-C port to the motherboard with AC Adapter connected, so the port is also fine. I am assuming there is a short on one of the power rails, but don't know where to start looking.
                        Any insight, schematic or boardview would be greatly appreciated.
                        Model: Lenovo Ideapad Flex 5 14ALC7...
                        11-04-2025, 03:49 PM
                      • PacoGT
                        HP ENVY x360 gidget 8L 203038-1, boardview and schematic need
                        by PacoGT
                        hello firends
                        i search the schematic or boardview
                        I have this motherboard, but I can't find the schematic or the boardview.
                        The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
                        So the computer doesn't turn on, and the 3V disappears after a few seconds.
                        The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
                        The new problem arose after removing the bad chip.
                        3V and 5V remained together,...
                        08-19-2025, 08:25 PM
                      • hosain0489
                        Request for Schematic and Boardview for HP Omen 16-xf0006AX (AMD Ryzen 7 7840H Version)
                        by hosain0489
                        I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
                        Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
                        If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
                        Thank you very much in advance!
                        07-15-2025, 11:20 AM
                      • re-atari
                        Gigabyte GA-H110-D3A schematic/boardview needed
                        by re-atari
                        Hello all,
                        Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
                        This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
                        02-24-2025, 06:45 PM
