Thank youuuu very much!
Macbook pro M1 A2338 820-02020 schematics boardview
Re: Macbook pro M1 A2338 820-02020 schematics boardview
Finally finished the task of creating the board view file and cleaning the schematic pdf
So if you find any error please reply here and will see if a can and/or want to correct them. ( 1 SIDE NOTE the ic UP102 and components are not on the actual board but are there to connect the signals)
So enjoy the hard work.Comment
Apple MacBook Pro M1 A2338 820-02020-A Boardview...
Channel: Schematics and Boardviews
by sdogsGreetings to the entire forum, I ask you for help because I'm going crazy. A dear friend of mine gave me a macbook pro M1 A2338 that only works with an external screen. With the internal one, no backlight or image. Only the external display is detected from the system settings.
First I changed the display flat, then I made a backup with time machine and tried a reset in dfu but nothing to do, always the same problem.
I analyzed the logic board, it shows no sign of liquid or visible damage. I then moved on to examine the logic with the thermal camera and found that the UP701 chip was... -
by User555111Currently Im trying to get this A2338 13" 2022 MacBook Pro M2 to function properly, Right now the trackpad and keyboard are not working but the power button and keyboard backlight are working. the Touch Bar shows display but does not respond to touch. I bought it on eBay and it was described as having a bad lcd. When I received it however I found that it was also missing the wifi and bluetooth antenna along with most of the screws hardware. it was also showing picture on the LCD but no backlight, I could also see some lines on the screen indicating the lcd was also somewhat damaged. on top...
by Schluchti45I have a MacBook Pro A2338 M2. The MacBook runs with the power supply unit. The fan runs permanently and the battery shows the message “Service recommended”.
I have already replaced the battery with a new one, but this has not helped. I have also tried DFU and the system restored the error remains the same.
Do any of you have any ideas where I could look or how I should proceed here?... - Loading...
