m6800 need sch
  • emaghanim
    • Dec 2014
    • 133
    • egypt
    m6800 need sch
    need la-9781p or la-9782p for m6800 dell
    thanks
  • Sprite08
    • Dec 2017
    • Vietnam
    Re: m6800 need sch
    i have LA-9781p
    • jim.moran
      • Aug 2024
      thanks, I've been looking for a while for this
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • Akhlz001
        by Akhlz001
        09-20-2025, 07:15 PM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
        Dell Thunderbolt Firmware
        by SMDFlea
        Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
        Some models have a choice of 2 different firmwares, it depends on the dell SKU.
        The SKU is in brackets (****)
        EDIT: NVM65...
        01-26-2025, 06:22 AM
      • F R 2568
        Dell Latitude 5420 does not start (no post) need help to find the reason why
        by F R 2568
        Hello all,
        this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
        I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
        If the laptop is only connected to the AC adapter (battery removed):
        When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
        The power/battery...
        01-08-2025, 05:45 AM
