Lenovo ideapad Gaming 3 nm-c871 schematic !
  • David Suarez
    • Apr 2025
    • AntioquĂ­a
    • dextrous zombie
      • Apr 2025
      • India
      Originally posted by coelectron
      Re: Lenovo ideapad Gaming 3 nm-c871 schematic !
      your request
      Thank you
      • Deby
        • Aug 2015
        • 52
        • Serbia
        Here's a scanned motherboard if anyone needs it.
        • nickojean22
          • Aug 2018
          • 15
          • philippines
          invalid file
          • Nagyesz
            Lenovo IdeaPad Gaming 3 15ACH - Ideapad 3 well known solder joint issues
            by Nagyesz
            I have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
            All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
            How can I extend its lifespan? Could reflow help?
            It has ryzen 5 5500h, rtx 2050, no soldered ram.
            Example of the artifacts:
            03-01-2025, 11:11 AM
          • Bonzas
            Lenovo IdeaPad Gaming 3-15IHU6 (Type:82K1) LA-L161P G0G10 Schematic and Boardview
            by Bonzas
            Hello, Lenovo IdeaPad Gaming 3-15IHU6 (Type:82K1) LA-L161P G0G10 Rev. 1A maybe someone have this schematic or boardview ?
            Thank you
            05-06-2023, 01:08 AM
          • mrgumshot
            Lenovo Ideapad Gaming 3 15IMH05 - BIOS REQUEST
            by mrgumshot
            I've got a Lenovo ideapad gaming 3 15IMH05 with a black screen issue. I've tried a BIOS file which i saw in another post and changed some things in a Hex editor.
            So i transfered the DMI info from my original BIOS to the one i got from the post. Flashed it to the chip and the laptop was booting again but very slow post.
            After a couple of boots it went back to black screen again. Tried to flash the same BIN file on it which i used before but its staying at the black screen now unfortunately.
            I hope someone can help me out. Attached is my ORIGINAL...
            05-02-2024, 12:18 PM
          • alex26
            Lenovo ideapad gaming 3 laptop. I did a big mistake
            by alex26
            Hello. I have a Lenovo ideapad gaming 3 laptop. I did a big mistake, more precisely I powered a laptop with 61V instead of 19V. I found a shorted coil and injected 1v. TPS65993 is heating up. I powered it through the rectangular plug, not through USBC. It is possible that this integrated circuit has burned out. I can't find a datasheet. TPS65994 can be found at Mouser but I don't think it is a good replacement. This TPS65993 is PD controller.Thanks. Motherboard code is HLG30 LA-L916P.
            05-06-2025, 01:37 PM
          • AleX.dans.les.nuages
            Lenovo Ideapad Gaming 3 15ACH6 doesn't charge
            by AleX.dans.les.nuages
            Hello from France
            My daughter spill some water on her laptop... Lenovo Ideapad Gaming 3 15ACH6, and she doesn't seen anything wrong after just remove the water with towel.
            Then, later the laptop won't start anymore.
            I've made a basic troubleshoot with my own laptop (same series)
            So, the computer battery is totaly out. With my battery, the computer works !
            But, with PSU connected, the latptop detect the power.. the harware led white is on, the amber one too and on the screen there is a 'batt charging' message.
            But...
            04-13-2025, 12:38 PM
