Hello, I have a 14" ASUS ROG Zephyrus GA401IV-BR9N6 that has a blown inductor that goes to pins 1-4 on the EDP panel connector and am trying to figure out the value so I can replace it.
Need Schematic for ASUS ROG GA401IV-BR9N6
Re: Need Schematic for ASUS ROG GA401IV-BR9N6
this is pretty close, ga401ih, i found it to be close enough
also a png of a boardview i can't find anything better for free online. it's enough to kinda get the idea of where all the inductors are and what the differences are
strange to find something for asus that isn't in fz format though
as for your original question, it looks like l4502, all the schematic says is 120ohm no current rating but that makes no sense as the thing would be dropping nearly all the voltage and while inductors often specify dcr on the schematic they never just specify that
elsewhere it says panel imax 0.485A and shows either a current limited power distro switch or a plain 1.5A fuse in series with the inductor so i'd think it's actually something like a 120uH 5A inductorAttached FilesLast edited by oddbondboris; 12-07-2022, 06:00 PM.Comment
SMD ferrite bead, 120 ohms is impedance at 100 MHz. Current rating is important too but not specified here, with a fuse in series it should be higher than what the fuse is rated for.OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
Hi, I'm uploading here what i found so far
Schematics+ board pdf for GA401IH (first page also says GA401IV GA401IU )
Board view .FZ for GA401II
The .pdf on post #3 "disappeared"Comment
by m.a.shHi i need help with Asus Zebook pro 14 ux6404vi schematic or Boradviews
i have ic damage (Bknn 023 ) i need same ic icant find same ic , so i need file Schematic or Boardviews to find ic info .-
Channel: Schematic Requests ONLY!
09-04-2025, 03:51 AM -
by Fisch46I'm not new to this board but this is my first posting so I hope I'm doing this right. I'm looking for the schematic for a ASUS N550JV motherboard P/N: 60NB0860-MB1B10. I have the board view but need the schematic also. TNX
07-31-2025, 07:12 PM -
by whatamidoingHello,
i'm looking for a schematic/boardview for an ASUS E3-PRO V5 (NOT E3 PRO GAMING, has a different layout).
I'm trying to find out where i can find SKTOCC# other than from the socket in order to ground it for a Coffee Lake mod. It must be somewhere near/around the SIO but I haven't found a datasheet for the NCT5539D this board has.
I've also found the schematic for the similarly named E3 PRO GAMING V5 but it has a different SIO so it's not of much help. And I don't trust myself to hold still a multimeter probe on top of a LGA socket pin to find where it comes out the...-
01-18-2025, 09:17 AM -
by mysnoopyHello
I need schematic for this model ASUS FX516PC R6.0
Thanks.-
12-27-2024, 03:41 PM -
by Kirve"Hello friends. My Asus X556U laptop is not charging, not turning on, etc. I wanted to repair the motherboard, partly for learning purposes. One of the capacitors is giving a 24V output, and one of the MOSFET pins is also giving a 24V output, and honestly, this surprises me. I think I need to replace the capacitor, but I don’t know the capacitance value. I tried searching for a motherboard schematic but couldn’t find anything. Can you help me find the schematic or diagram?"
- Loading...
