samsung r530 need schematics
  • String2016
    • Nov 2015
    • 2229
    • philippines
    I need a schematic on this samsung r530 BREMEN-C rev 1.0(100106)-3 . problem turns on but display comes but screen is blank no data already tried replaced good screen same issue
  • peste
    • 12295
    • ROMANIA
    Re: samsung r530 need schematics
    read post # 6
    https://www.badcaps.net/forum/showthread.php?t=37765
      • 20412
      Samsung_R530C_R730C_BREMEN-15C_17C_r1.0
      • Chrissygizmo
        by Chrissygizmo
        02-10-2025, 12:33 AM
      • Chrissygizmo
        samsung galaxy ao2s very temperamental after screen replaced
        by Chrissygizmo
        Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
        Ive eventually managed to get it on and working but it's very temperamental...
        The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
        05-26-2024, 12:05 AM
      • Kiberge
        Samsung LH82QENELGC/EN Help needed - Static line on screen
        by Kiberge
        HI guys!
        I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
        I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
        the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
        This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
        04-22-2024, 11:28 AM
      • arbitarytwist
        Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
        by arbitarytwist
        Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
        Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
        03-01-2025, 01:16 PM
      • trepachka
        HP Probook 450 G8 Boardview+Schematics - screen backlight issue
        by trepachka
        I am just wondering if anyone has boardview+schematics for HP Probook 450 G8.
        Computer is missing screen backlight. The backlight fuse must be kaput. I know the fuse is located on the motherboard because we tried a different working screen and it, too is missing backlight.
        Perhaps, if the boardview+schematics are not available, someone can point out where the screen backlight fuse is located. Thanks.
        03-16-2024, 12:32 AM
