HP FPW50 LA-H323P have anybody schematic or BV?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3598
    • slovakia
    Guys im in need of schematic or BV for HP FPW50 LA-H323P
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3598
    • slovakia
    Re: HP FPW50 LA-H323P have anybody schematic or BV?
    please guys im stuck without it
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3598
      • slovakia
      nobody?
      • anshad
        • Nov 2010
        • 249
        Originally posted by ktmmotocross
        nobody?
        I guess so. Newer HP Compal OEM board's schematics can be found nowhere in the Internet - not even on the sites which sells harder to find schematics for a premium price.
        • reformatt
          • Feb 2020
          • 1414
          A 15s-du1016TU (with a LA-H323P motherboard) came in dead with water damage. A number of areas were affected, mainly a number of QFN's. Board worked ok after rework. I took the opportunity to grab some voltage references off it for future reference as there's no schematic currently available.
          Some other stuff:
          PU301 SY8286BRAC +3.3V (AWV)
          PU302 SY8270CTMC +5V (BTX)
          PU1001 SY8286RAC +1.08V (BAA)
          PUB1 BQ24725A (BQ25A Battery IC)
          PUM1 G5616B 1.2V (DDR4 Buck converter)
          PQA1, PQB1, PQM1 EMB09A03HP FET
          EC is ENE9022Q and programmable.
          • reformatt
            • Feb 2020
            • 1414
            SVOD programmer keyboard pinout for the ENE9022Q
              • 20984
              KB_pins=32 1MM DOWN LEFT KSO3=15 KSI4=28 KSI7=31 KSI6=30 KSI5=27
              • inbargains
                • Apr 2013
                Some other stuff:
                Sorry to bother you but I'm trying to repair one of these boards and appreciate you taking time to post this information. The board I'm trying to repair is missing the +0.8~1.1V rail. I checked PQA1 and I do have 20V on the high side but only 0.2 on the output. I thought maybe I'd get lucky and it was just the FET so I swapped it with PQB1 as I had 3v out of it without a battery so I knew it was working. No change at all.
                History, this board was working fine until I opened it up to upgrade the NVME. I disconnected the battery and when I put it back together I get the dreaded 5 long flashes 3 short on the caplock.
                All the other rails are present and correct. I can't determine what triggers that PQA1 FET and the mosfets in that circuit to power the CPU. The SIO by chance????
                • abrar
                  • Dec 2016
                  • 31
                  • pakistan
                  thnx
                  • wilmer javier
                    • Nov 2020
                    • peru
                    Some other stuff:
                    hello, good afternoon, I received a plate just like this one, and I need to know the value of the plm2, which in my case is blown up or burned, that's your answer, thanks
                    • outta
                      • Dec 2012
                      • 18
                      • Mexico
                      From a similar board and some info here and there I guess you can use FBMA-L11-201209-121LMA50, which is a 0805 size, ferrite bead, 0.19uH, 5000mA. Keep in mind it blew because a short circuit after it. Check PQM1 and PUM1. They are likely bad.
                      • wendel
                        • Feb 2022
                        • El Alto
                        I hope it helps, see you later
                        • Delwar
                          • Jan 2019
                          • 8
                          • bangladesh
                          thanks
                          • dgs3342
                            • May 2017
                            • 36
                            • Italia
                            • anceng
                              • Nov 2020
                              • 19
                              • Philippines
                              what application you use on this file. thank you
                              • dqtech
                                Badcaps
                                • Jul 2018
                                • 630
                                • N/A
                                thanks
                                • M4n0l0307
                                  • Nov 2020
                                  • 165
                                  • Colombia
                                  Thanks Friends !
                                  • gmacz
                                    • Jun 2018
                                    • 38
                                    • Sri Lanka
                                    Thank you
                                    • cherif 16
                                      • Aug 2021
                                      • 9
                                      • algeria
                                      THENKS FREND
                                      • asliyucegsm
                                        • Jun 2011
                                        • 347
                                        • Turkiye
                                        thank you friend
